repairing a d-link wireless access point power supply
Peter
I have a couple of d-link wirless accesspoints on whose power supplies have
failed - they should deliver 5volts at 2 amps.
The power supply takes the form of a slim-line plug pack.
Inside the pack is a little switch mode power supply.
I'm looking for some tips on what to look for in repairing this item. there
is nothing obviously wrong on a visial inspection. Fuse is intact, no heat
stress on the board, no visually distressed components. Just nothing on the
output.
On the board there is a pwm chip - CM3842 - an 8 pin device. There is 8
volts on its Vcc pin (pin 7) - nothing appreciable on any other pins.
On there board there is also a 3 legged semiconductor - probably a FET -
Number is ST W55403 (then Morocco P4nK602 FP0) it's an all plastic device -
ferrite sleeve on its middle leg. It has 320 DC volts on its middle leg -
nothing on either of the other 2 legs.
Windings of the transformer show continuity.
I'd like to get this working again - I've been quoted $55 for a replacement.
Pic of the board can be seen at:
http://members.ozemail.com.au/~pebarhug/images/d-linkpsu.jpg
TIA
Peter
Phil Allison
"Peter"
** Wrested with a couple of those just lately.
There is 8 volts on its Vcc pin (pin 7)
** Takes 14 volts to initiate the kick start process.
First check the circa 100 kohm resistor that feeds the PWM IC with DC -
it may have gone high value.
Then if that is OK, connect a scope to the tranny secondary winding and
watch for signs of kick starting.
........ Phil
Peter
Phil Allison said:
"Peter"
....... Phil
Thanks Phil
Pin 7 is fed from 320 Volts via a 300K (on value)nd it is held at 8 volts by
a zener...no intelligible markins on the zener though. I see in the specs
the chip needs 14.5 to start and 8.5 min operating voltage.
I'll try to get a working unit and compare
Phil Allison
"Peter"
by a zener...no intelligible markins on the zener though. I see in the
specs the chip needs 14.5 to start and 8.5 min operating voltage.
** An external zener needs to be between 20 and 32 volts.
There is a 34 volt zener ( or equivalent ) inside the IC from Vcc to ground.
Standard 3842s will not reliably start with a 300 kohms feed resistor -
only the low current versions will.
There should also be a small electro from Vcc to ground - check it has not
gone high ESR.
You DO have a Bob Parker ESR meter
DON'T YOU ????
........ Phil
Peter
Phil Allison said:
"Peter"
ground.
not gone high ESR.
DON'T YOU ????
....... Phil
No I don't have one of those - should though!
The problem was a faulty 0.01 ceramic cap from pin 2 to pin 4 of the pwm
chip.
After replacing that all worked
Peter
Phil Allison
"Peter"
chip.
** So you lied about there being two such units ?
Just goes to show that all NG questions are trolls.
........ Phil
Peter
Phil Allison said:
"Peter"
No I did not lie about anything. On the other unit while testing the FEt my
probe slipped thus shorting it The middle leg had 319 volts on it. On
reconnecting to the power - sparks, smoke, flash, the pwm chip
disintegrated.
Peter
