Repairing lifted solder pads
Russ
I have wanted to repair some lifted solder pads at times but the kits
that I have found sell for hundreds of dollars. I just want the glue
part and a sheet of copper. Does anyone know what kind of glue that
can be used to replace a solder pad? I think I can find a thin sheet
of copper but I am not sure of the glue that will hold up to the
heat. Any ideas for the financially challenged?
Russ
N
N_Cook
Russ
Broken pcb traces and pads, bridging pcb holes that are too small for the
component leg going throuh, so solder cracks, etc
Eventually found a hobby shop with what I was after
2 copper and 2 brass 80 mesh 5 x 6 inch sheets, bit finer than I was after
but finer is better than coarser.
Amaco of Indianapolis , Wireform Metal Mesh and Wiremesh woven Fabric.
Presumably bigger sheets of it are used by the mind control nutters.
A 2 hole paper punch makes neat 5mm pads and a needle to make a pilot hole.
If lifted pads from use of a "proper" desolder tool, try a hot air gun ( No
flaming please) try it first, explained on the tips files off below
Jim Yanik
Well if you are working on small SMD stuff, I use super glue
(cyanoacrylate), and a piece of small wire to bridge the gap if the
trace is broken. Sometimes the trace is too small and I just bridge it
with solder. The problem with super glue is that the fumes it produces
are like tear gas, but it usually sticks ok. There have been many
discussions about this topic in the past. Try doing a search for it.
Mike
I also used salvaged pads/traces from scrap PCBs,and used eyelets to hold
down the pads.you can cut off a worn hex key,chuck it in a drill,and grind
down the end to a cone for cinching the eyelets.Eyelet kits I've used had
two rods with conical tips,one fit into a metal block for holding it erect
to support the backside of the eyelet while you tapped down the topside of
the eyelet with the other tool.
Never found any useful glue that would hold up under soldering,though.
N
N_Cook
Jim Yanik
jyanik
at
kua.net
Is that set small conical ended hex rod in a drill to sort of grind a
stopped hole in the pcb . Then press fit an eyelet down into this enlarged ,
cone bottomed hole as in friction fit cinching process?
Jim Yanik
enlarged , cone bottomed hole as in friction fit cinching process?
no the conical rod/hex key is a tool to flare out the eyelet.
The drill part is to make a conical end on the hex key rod.
I chose the hex key because it's tool steel and was available,you could use
an old drill bit.
I use a drill bit to drill holes in PCBs.
Russ
Thanks everyone, a few more thoughts.
I sometimes can't use a a wire type repair and really need to have
that pad back so that it is anchored to the board for strength. I have
tried super glue but it didn't hold. I went to an auto store and found
the best High temp two part glue they had but it didn't work. I think
the way they repair these things is to use thin copper sheet with a
two part heat activated epoxy. Any ideas or links to the glue they
use? I am thinking Loctite might make something like this so I will
call them asap.
Thanks again
Russ
N_Cook, I am not sure about the "Amaco of Indianapolis" Is this where
you buy the thin copper? Is it a arts and crafts store?
N
N_Cook
call them asap.
Thanks again
Russ
that was the product name , otherwise bought at
http://www.hobbycraft.co.uk
Anyone aware of a punch mechanism , smaller than the usual 5mm desk paper
punches ? Leather punch pliers have to be really sharp to cut this copper
mesh as its not a punch through operation.
bz
Russ
You can buy rolls of copper that has an adhesive on one side.
http://tapeinfo.com/TapeInfo/Datasheets/Permacel/673/P391.aspx
and sheets such as
http://webtronics.stores.yahoo.net/cf-3.html
and
bz 73 de N5BZ k
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
