Replacement for 2SK533
pier1
Aug 21, 2006
180
I need an equal replacement for the part number 2SK533.
This device is used in a Flow control board which is gone bad. I need to replace this with an alternative part and many vendors say that this part is no more manufactured.
If any one knows about this part please contribute. I am not able to find a datasheet for this part. All that I got is attached.
datasheet2.pdf
  • datasheet2.pdf
audioguru2
Apr 6, 2004
12,022
You don't have and I couldn't find a proper detailed datasheet.
We don't even know if it is an N-channel or P-channel Jfet.
Since its IDSS (typical?) is listed as 9mA then try a 2N5459.
Hero999
Oct 28, 2007
2,433
It's definitely N-channel.
The current is specified as a positive figure (P-channel devices are often specified as negative) and of the PDFs I found using Google says so.
The maximum IDS is 30mA, the characteristics are specified at 9mA.
hotwaterwizard2
Jan 8, 2004
2,022
http://www.electronics-lab.com/forum/index.php?topic=22061.new#new
2sk533
http://english.electronica-pt.com/db/cross-reference.php?ref=2SK533
http://english.electronica-pt.com/db/cross-reference.php?ref=2SK523
2SK523 is a substitute
http://www.freeservicemanuals.net/index.asp?q=1
Part Specification
2SK533K
N-Channel JFET
NEC Electronics
field effect transistors,transistors
V(BR)GSS (V)=50
I(D) Abs. Drain Current (A)=30m
I(G) Max. (A)=10m
Absolute Max. Power Diss. (W)=400m
I(GSS) Max. (A)=100p
@V(GS) (V) (Test Condition)=20
V(GS)off Min. (V)=.2
V(GS)off Max. (V)=1.2
@V(DS) (V) (Test Condition)=10
@I(D) (A) (Test Condition)=10u
I(DSS) Min. (A)=1.0m
I(DSS) Max. (A)=5.5m
g(fs) Min. (S) Trans. conduct.=7.0m
@I(D) (A) (Test Condition)=1.0m
C(iss) Max. (F)=13p
Package=TO-92
Military=N
HP part #1855-0571
Possible Subs
BF244a
J310
2SK162
2SK163
2SK170
2SK523
2SK533
2N5417
Available in stock
http://www.mark5.co.uk/partsenquiry.php?id=2SK533
(NEC) N-CH J-FET -50V 0.01A T0-92 (53B)
http://engisys.info/mosfet/transistor.php?transistor=729
