Hello. I have a project that uses 52 of the ISD1820 voice recorder modules and I have wired them all to a 6V power supply in parallel, but it all overheats very quickly as is. I am trying to figure out the resistance of the entire circuit and include the required resistor, but am not sure if I am doing it correctly. Can anyone help? Each module draws approx 20ma while it is playing and they will all be playing at the same time, all the time basically. I believe each module has a resistance of 300 ohms (6V / .020A). Therefore because they are all in parallel I used the reciprocal 1 / 300 = .003333 and because there are 52 of them the total circuit resistance is (52 x .003333) = .173316 ohms. Therefore because the overall circuit resistance is so low, it attempts to draw 34 amps which could be why it is overheating. I believe that if each module needs 20 ma the overall current draw should only be 1.04 amps (.020 x 52). Should I be using the calculation of 6V / 1.04A = 5.769 ohms? If this is the case, I should put a 5.769 ohm resistor in series with the entire parallel circuit. Does this sound correct?
