Reverse Color Organ
Jon Jerpbak
Jul 24, 2015
3
Using a light organ (Velleman MK114), I want a light to turn off to the music rather than turning on. This means the normal state of the light is on. I've tried using a NOT gate but the voltage coming out of the color organ is quite varied and the NOT gate is just on/off. I do not have access to an oscilloscope.
I'm looking for a device or circuit that will adjust the output voltage depending on the input voltage.
As an example:
Assume that the color organ out put voltage is anywhere between 0v and 9v.
If the input of this 'new' circuit is 0v, i want the output to be 9v.
If the input is 3v, i want the output to be 6v.
if the input is 9v, i want the output to be 0v.
I just need to be pointed in the right direction.
AnalogKid
Jun 10, 2015
3,058
Please post the Velleman schematic. In the mean time, it sounds like you are asking about an analog inverter. Not the same as a digital not gate because in your case there is no implied reference to invert things about. An inverting opamp with an offset of Vcc/2 or 4.5 V will do what you describe. Whether or not it will work in your application is a different thing.
aka
Jon Jerpbak
Jul 24, 2015
3
Thanks for your answer, I'll start looking into your suggestions. I have attached the schematic
Alec_t
Jul 7, 2015
3,821
....and disconnect pin 4 of the opto coupler from ground.
