Reverse Day/Night
SparkyCal
Mar 11, 2020
863
As you know, there are plenty of devices that will turn on lights when it is dark out, and turn them off in the morning.
I have a pond however, whose pump I want on in the day, but automatically off at night. Is there a circuit that can do this? Bear in mind that the pump plugs into 120v
Thank-you
Alec_t
Jul 7, 2015
3,820
You could use one of those devices to switch the coil of a SPDT or DPDT relay. Use the relay contacts to switch the pump.
SparkyCal
Mar 11, 2020
863
Is there a schematic for that somewhere. I am not versed enough to understand that.
AnalogKid
Jun 10, 2015
3,055
What is the operating current or power for the pump motor? It should be on the label.
ak
Minder
Apr 24, 2015
3,561
There are a multitude of 555 LDR circuits out there (Google), you would just need to juxtapose the pot or res with the LDR to get the reverse action.
If an AC pump, use a relay on the output, if DC, a Mosfet.
M.
Normally swap the position of the LDR for whichever light/dark.
