revolving chandelier with a way to plug in led strips
Crafts4Me
Feb 10, 2022
175
currently i am using an revolving Xmas tree holder with plug adapters
1- i am using it upsidedown form the ceiling
2- it revolves the wrong way because its wrong side up
a regular motor wont serve my needs because i want the ability to plug in light stips and a regular motor will turn and then snap the added strips
i am not sure i want to build the entire motor and light strips form scratch
any ideas?
Martaine2005
May 12, 2015
5,318
Have a look at ‘slip rings’.
They’ll do exactly what you want.
Martin
Crafts4Me
Feb 10, 2022
175
what does that mean?
i need the idea of a tree holder but perhaps self made so it revoves clockwise and can be plugged into
Martaine2005
May 12, 2015
5,318
The tree holder can probably be adapted to run the opposite way.
Can you show photos of it and the insides?.
Martin
Delta Prime
Jul 29, 2020
2,996
Slip Ring Do you have a hair curler it's on the end. Allows the power cord to swivel without interrupting the power flow.
any ideas?
Another approach would be to install the LEDs stationary ( not special requirement such as slip rings) and have the light fittings relvolve around the LEDs.
Without any detailed drawings of your setup it is almost impossible to comment in any helpful way really.
Suffice to say a certain amount of mechanical setup will be required by you but I have a feeling it is beyond your ability given your previous response.
Crafts4Me
Feb 10, 2022
175
i need to somehow create on my own the idea of anxmas tree holder that spins and i can add more plugs to it
any ideas?
Martaine2005
May 12, 2015
5,318
Help us to help you!
Give all the information you have instead of us keep asking you!
Show photos.
What voltage is it etc..
As already suggested, you can use a slip ring or have a motor turn the outer ‘shade’ and have stationary lighting inside.
Martin
Crafts4Me
Feb 10, 2022
175
please explain slip ring and outer shade
this is hanging using an xmas tree holder with the lights plugged into the tree base
i really need 220v this ones 110, also since its a ready base and upside down it turns ccw and i need cw
can i replicate this on my own so i can redesign the crown and also add more lights
Crafts4Me
Feb 10, 2022
175
what would i look up to purcahse. the entire thing weighs maybe 10 lbs if not less
i need something small and manageable
Crafts4Me
Feb 10, 2022
175
the tree stand upside down rotates ccw i need CW its like the days of the week are revolving backwards
Crafts4Me
Feb 10, 2022
175
i looked up slip ring motor
looks like the idea i need. which style would i need if i want to wire more than 1 thing
Crafts4Me
Feb 10, 2022
175
hi almost
need for about 10 punds only this will break down the hut's roof
