scroll message on an LCD...
vead
Nov 27, 2011
473
Hello ,
I am making small project on software
Microcontroller 8051
language assembly
assembler- 8051 IDE
source code
Code:
ORG 0H
MOV A,#38H       ; command
ACALL COMNWRT    ;call command
ACALL DELAY       ;give LCD some time
MOV A,#0EH        ;display on, cursor on
MOV A,#01          ;clear LCD
MOV A,#06H        ;shift cursor right
ACALL COMNWRT    ;call command subroutine
MOV A,#84H
MOV A,#'V' ;display letter J
ACALL DATAWRT ;call display
MOV A,#'E' ;display letter J
MOV A,#'A' ;display letter J
MOV A,#'D' ;display letter D
AGAIN: SJMP AGAIN ;stay here
COMNWRT: ;send command to LCD
MOV P1,A ;copy reg A to port 1
CLR P2.0 ;RS=0 for command
CLR P2.1 ;R/W=0 for write
SETB P2.2 ;E=1 for high pulse
CLR P2.2 ;E=0 for H-to-L pulse
RET
DATAWRT: ;write data to LCD
SETB P2.0 ;RS=1 for data
CLR P2.2
RET
DELAY: MOV R3,#50
HERE2: MOV R4,#255
HERE: DJNZ R4,HERE
DJNZ R3,HERE2
RET
END
can someone tell me why message are not scrolling continuously on LCD ?
14,311
Why should it scroll?
As far as I can see you do nothing to make the text scroll. You write "VEAD" to the LCD at a single position and then stay in the idle loop "AGAIN". To make the text scroll you need to write the text to different positions or use a built-in scroll routine of the LCD, provided it has such a routine (which I doubt).
vead
Nov 27, 2011
473
could you please explain with small example ?
14,311
1 Set cursor to position 1 (leftmost)
2 write "VEAD"
3 Set cursor to position 2 (left+1)
4 write "VEAD"
5 Set cursor to position 1
6 Write " " // to erase the "V" from line 2
7 set cursor to position 3 (left+2)
8 write "VEAD"
9 Set cursor to position 2
10 Write " " // to erase the "V" from line 4
etc.
Alternatively:
1 set cursor to position 1
2 write "VEAD"
3 set cursor to position 1
4 write " VEAD" //one space before V
5 set cursor to position 1
6 write " VEAD" //two spaces before V
etc.
Clear display
write --------VEAD
pause
clear display
write -------VEAD
pause
clear display
write ------VEAD
pause
clear display
write -----VEAD
pause
clear display
write ----VEAD
pause
clear display
write ---VEAD
pause
clear display
write --VEAD
pause
clear display
write -VEAD
pause
clear display
write VEAD
pause
clear display
write EAD--------V
pause
clear display
write AD--------VE
pause
clear display
write EAD--------V
pause
go back to start
vead
Nov 27, 2011
473
I Did some google search. I looked some tutorial. I have divided code into subsection. I don't understand which section is wrong
LCD command
Code:
ORG 0H
ACALL COMMAND  ;call command
ACALL COMMAND    ;call command subroutine
MOV A,#84H
DATA Display
Code:
ACALL DATA ;call display
Code:
COMMAND: ;send command to LCD
RET
Code:
DATA: ;write data to LCD
CLR P2.2
RET
Code:
DELAY: MOV R3,#50
HERE2: MOV R4,#255
HERE: DJNZ R4,HERE
DJNZ R3,HERE2
RET
END
Now it's worse. It runs off the end of the program into the subroutines.
Do you have a loop anywhere?
vead
Nov 27, 2011
473
NO ,I did google search for assembly loop we can create loop using some assembly Instruction(jmp, djnz....) I think I need infinite loop
I am explaining example of loop
loop :
MOV R1 #54h
DJNZ R1
SJMP loop
Do you know why you need a loop?
No. You don't need to display a message continuously, you need to continuously update or change the displayed message.
gorgon
Jun 6, 2011
603
It's generally faster to write a space at the beginning or end of the scrolling text, than clearing the whole display. That normally takes several ms, and there will be a blink in the display. When writing characters, and space, the change is smooth. Or as smooth as the programmer can manage to do it.
This is of course dependent on the text displayed. If it fills the display line complete there is no need for adding spaces, since you replace the whole line every time.
Some of the display controllers have a scrolling function in built, by manipulating the start address of the display RAM in the display.
