Greetings All;
I recently squired a DC Lab power supply and seem to have an issue in setting up the current limitation on the unit.
The unit is SKY TOP Power STP3005 30V 5A power supply, I have listed a link to it below:
https://en.skytoppower.com/project/regulated-power-supply-stp3005-30v-5a/
The unit came with a small two page manual that covers setting up the current limit in two lines.
I tried several times to do this following there instructions but could not get the current limit set.
I went to U-Tube and found a couple video's of other small power supplies and followed there instructions but still the same result.
I believe that the issue is me not the power supply but there is a possibility that the unit might be defective?
I linked both the positive and negative leads together and made sure that the voltage was set to Zero. Then I moved the course setting Amperage button to Zero which then caused the CC led to come on,
then I moved the current knob clock-wise to about 25% of its rotation and at that point the LED switched from CC to CV.
At this position I could move the course voltage nob now and both the current and amperage would increase.
I removed the probes from being linked together and installed a LED bulb, the unit was in voltage mode and I increased the voltage and both values increase beyond the limit I thought I had set.
I would appreciate and instructions/comments that might assist me in getting the current limitation set.
