Shottky diode bridge for 6o Hz any guess why?
Bob T
I've been asked to reverse engineer a product that has a very unusual DC
power supply I'm trying to understand
It has a power transformer for the line with two secondary windings with a
shottky diode tying one end of each together
The outer ends of these windings are then connected to a 4 diode full wave
bridge made of more shottky diodes then to a conventional voltage regulator
I'm trying to understand why one would not simply tie the two outputs in
series and then feed a conventional full wave bridge
The output of this power supply is 12 Volts
the diodes are rated 8 amps but the transformer in my opinion is not capable
of that current as it is only 2"X2"X2"
Any opinions are appreciated
Thanks in advance
Thanks in advance
Dug thru my old books and found this little note. Why they used them,
the price was right!
Shottky barrier diode
Diodes are used to rectify alternating current into direct current.
However, rectification will not occur when the frequency of the
alternating current is too high. This is due to what is known as the
"reverse recovery characteristic."
The reverse recovery characteristic can be explained as follows:
IF the opposite voltage is suddenly applied to a forward-biased diode,
current will continue to flow in the forward direction for a brief
moment. This time until the current stops flowing is called the
Reverse Recovery Time. The current is considered to be stopped when it
falls to about 10% of the value of the peak reverse current.
The Shottky barrier diode has a short reverse recovery time, which
makes it ideally suited to use in high frequency rectification.
The shottky barrier diode has the following characteristics.
The voltage drop in the forward direction is low.
The reverse recovery time is short.
However, it has the following disadvantages.
The diode can have relatively high leakage current.
The surge resistance is low.
Because the reverse recovery time is short, this diode is often used
for the switching regulator in a high frequency circuit.
Gary S. Bahret, EE, PhD
Phil Hobbs
Thanks in advance
Could you post a schematic? I'm not visualizing what you're describing.
Cheers,
Phil Hobbs
