John Larkin wrote:
krw wrote:
krw wrote:
b. I often have situations where, say, an opamp or comparator switches
the supply of another. This can become next to impossible to understand
by other engineers, especially younger ones.
In our case there is always a PIC in the middle. I don't know how to
show the power control code on the schematic. ;-)
So far I never had a PIC in the middle ...
When I first wrote "PIC" I was kidding; the answer to every question
is "PIC". The fact is that we do have a PIC in the middle, on top of
a DSP.
Dead-bugged on top of it with liquid nails glue ...?
Cadsoft Eagle allows a very nice flexibility here: You can call up the
power pins via the "invoke" command. The CAD symbol is usually drawn so
it slides over the A-device (or another if you wish) and fits as if it
was part of the symbol. You can also place it near the group in the
schematic, or down at the bottom for simpler architectures. That's how
it ought to be, gives the designer all the freedom.
That sounds like it solves all the problems.
Sure does. That CAD program is very close to perfect. With one major
deficiency and that makes it IMHO useless for any larger design: No
hierarchical sheet structure :-(
Monday we had the design review for the widget I'm working on. My
boss really liked the hierarchical (turtles all the way down)
organization. I'm not so sure about the other hardware engineer
though. ;-) I'm still not to where I can easily determine where to
add a hierarchical block or another sheet though. More than one block
for a component (FPGA) just seems wrong.
Yes, I would never, ever, split a component across several sheets or
even just blocks. That makes a royal mess out of a schematic.
Thing I'm doing now, the PLX PCIe chip is three "gate sections" (pcie,
backside bus, power) across two sheets. The FPGA is 8 sections (one
for each bank, 450 pins or so total) across three sheets. This one
board is a 22 sheet schematic... B size sheets.
You never split gate or opamp sections between sheets?
Nope. Only exception is simple logic gates but even then you'd almost
have to twist my arm.
I never do hierarchical schematics. Everything's flat.
Then we have almost opposite CAD habits. But at least we have similar
beer taste, only the good stuff
What happens to reference designators in a hierarchical schematic?
