F
Fred Abse
- Jan 1, 1970
- 0
If you're completely confident your assembly guys won't inadvertently
subsitute 5% resistors on you when you mean 1%
They wouldn't be *my* assembly guys very long, if they did.
life said:No, idiot. The one you posted a link to was a 5 watt power resistor.
And, as I stated, it is a High Voltage Resistor.
You did not read what I wrote. These are not standard, everyday parts,
they are purpose specific.
I know what it smells like when it burns (the PCB media), so that alone
should tell you enough. That memory originally dates back to the late
sixties. Of course subsequent events indicates further experience.
life said:Answer: I have some experience in electronics manufacturing, including
the use of bulk media (not count, material of construction) and high
voltage types of resistors. I have seen a large array of what can be
expected in resistors. I am sure there are those I have not seen.
I have seen resistors that stop trains.
They are not as cheap as you might think. Those are "pulse
withstanding" thick film devices, and I'll bet that they ALL cost more
then the std Vishay stuff in the local catalogues.
So, maybe you should look closer... and again.
Piss on RoHS, I am exempt. I don' need no stinkin' compliance badges...
Fred said:That's the way I've always done it.
JosephKK said:]
E12 values in 1% are as common as mud, everyone uses them, mostly due to old
habits as everyone has the E12 range drilled into their head.
Dave.
Alas, i design to E24 by default. But back when i was starting i
found the premium for E24 parts to be worthwhile. The habit remains.
Raveninghorde said:I left that world behind when I left STC. I never got involved with
fibre though STC were working on it.
The high rel requirement led to conservative design approaches. PCBs
were only just being introduced in 1976, everything before then was
made on custom tag boards with tags mounted on perspex. The fear was
that chemicals could leach out of the pcbs over 25 years in a sealed
environment and lead to corrosion and failure. Even the resistors were
unmarked so that the paint dyes could not leach out.
Looking at the responses it is clear that E96 resistors are considered
standard in the US. In my experience that is not the case here in the
UK.
"Our
Chinese contract manufacturer is asking which of those 5% resistors we
can ease off to 10% or more.
. That kind of ROI is stunning. Yet none of this
seems to be taught at universities or anywhere else and most people
don't bother to educate themselves about it, probably because it's
perceived as boring.
Someone who has ever designed with a team in Asia (I have) knows the
drill.
They had reams of computer paper hung on hallway walls, updated
about weekly, with fresh commodity pricing of electronic parts.
And yes,
all the way down to the lowly resistors and diodes.
This wall is what
drove the design process, not elegance or whatever.
krw said:Does anyone's "assembly guy" stuff 1K 1% resistors, rather than
P/N 1234567? Why does the "assembly guy" even care if it's a
resistor?
It does help if assembly folks know what part is what kind. For
temperature profiles and such. The guys rigging the machines don't need
to know as long as they follow proper ESD procedure.
krw said:Our "assembly guys" (mostly women, actually) know what process to use
on which products and how to profile them. They have no need to know
what's on the boards, other than inventory numbers. The "assembly
guy" doesn't decide which profile to use. The people doing rework
(sometimes the same people) need to know a little more, perhaps.
Well, I meant the personnel at the assembler, not just the workers on
the floor. The foremen and similar folks do need to know IMHO. I would
not advice a client to use a shop where that wasn't the case.
krw said:Ah, you're including the "manufacturing engineering" people in the
"assembly guys" bucket. I was restricting the group to just those who
push the buttons and load the pick-n-place machines.
Not always real engineering. But it does help if the line lead or at
least the foreman knows a thing or two about this stuff. Older ones can
be more knowledgeable than engineers assume. I was once called to a
serious production problem, nearly all boards failed final test. Asked
their engineers whether they had a sit-down with production people.
"Uhm, no, why?". So I had that sit-down. Problem looked like board
warpage. The foreman and I quickly figured out what could be done, for
lunch we headed to a place where there was a large hardware store.
Bought some lumber there, made a few "pre-stretch" frames, sent some
boards through -> all passed.
Jim said:Sometimes pisses managers off, but I often go around the manager and
talk to the "down-stream" people to sort out what a chip design
_really_ needs to do.
krw said:[...]
Warpage? Pre-stretch? Must be some warped boards to cause failures.
We have some fairly large boards (half-panel) with a lot of heavy
stuff (audio transformers) on them and haven't had too much trouble
with warpage. Certainly no big fallout in assembly.
Tek's motto used to be, "Committed to excellence."
Now it's "Enabling innovation."
Hmm, OK, but I really think the old one was a stronger statement...
Anyone have a list of company mottos over the years? I would imagine Tek had
more than the two I've listed here, HP must have had a bunch, etc...
