Simple millivolt to 5V amplifier module
Wester de Weerdt
Sep 4, 2016
4
Hi, guys.
I have been developing gad detecting system with Arduino.
My O2 sensor is 4OXV CiTiceL Oxygen sensor.
http://www.ebay.com/itm/UK-CITY-4OX...0883143&pid=100034&rk=1&rkt=2&sd=181596912854
In theory in normal air which is 20.9% oxygen the mA coming out of the sensor should be around 0.10.
The 4OXV is basically a current generator. All you need to do is to put a load resistor across the 2 sensor pins, measure the volt drop across the resistor to determine the current flow. This current flow is proportional to oxygen concentration.
I put load 100 ohm resistor across the 2 sensor pins, the output voltage will be around 10mV.
So I need simple millivolt to 5V amplifier to read this value with Arduino.
Is there any built-in breakout board?
(I have found the Sparkfun OpAmp Breakout board - LMV358, but this circuit is AC coupled and is therefore not suitable for use with our sensors.)
Thanks.
What would output be for a 1K resistor?
Bit conflicting info as the spec says it outputs 9 to 13mV in air.
Do you need it to trip a circuit or more range as Arduino analog input will convert 0-5v into 0-1023.
Other than that a standard opamp should do it.
Wester de Weerdt
Sep 4, 2016
4
Thanks for your quick reply.
I wonder if you could inform me about the standard opamp breakout board.
I am asking since I do not want to soldering at all.
Thanks again.
W.W.
Wester de Weerdt
Sep 4, 2016
4
Yeah.
I have read this forum twice before posting here.
But they did not mentioned about built-in breakout board.
Would you mind to tell me about breakout board which does not need to solder and just needs to wiring?
(I am in the prototype status and I need to check proof of concept of my product.)
Thanks.
W.W.
P.S.
I have found this:
http://www.analog.com/en/products/l...millivolt-and-voltage-input.html#Introduction
But it's price is amazing!!! ($98)
