Simple Potential Divider Circuit - Need help with voltages
ElectStudent
Apr 8, 2014
13
Please see the diagram i have attached.
What will be the voltages across the resistors?
what effect does the 1.5V voltage supply have on the voltage across the resistors?
V(midpoint between R1 and R2) = 7.5V, so does that mean V(r2) = 7.5?
Laplace
Apr 4, 2010
1,252
The 9V divides between R1 & R2. However, the measured voltages referenced to ground are offset by 1.5V.
ElectStudent
Apr 8, 2014
13
Thank you, so does that mean the 1.5V supply has no effect on the circuit apart from when measuring voltages?
Laplace
Apr 4, 2010
1,252
Does any current flow through the 1.5V source? If so, what path does the current follow?
