Simple watthour meter?
W
Walter E.
I would like to find out how much power my refrigerator is using over the
course of month.
Are there any inexpensive watt-hour meters on the market? Something I could
build with my AC ammeter?
Thanks for any input
N
Nick Hull
course of month.
If you know the power it uses when on, you could wire an electric analog
clock on to the compressor and it will show how many houre it is running.
safemale
i use the Kill A Watt
its super i love it
amps volts voltamps and power facter too
david
how about the use of digital multimer is there a way a person can use one as
a watt meter to measure how power is being used?
W
William P.N. Smith
Well, sort of. You can measure (RMS) current and (RMS) voltage and
multiply them together, but since you can't measure power factor, your
number will be higher than the real power you are drawing from the
power company.
[However, homepower generators and inverters are current limited, so
current drawn is a useful number there.]
OTOH, real watt-hour meters aren't expensive...
safemale
butt the killawatt
it do look at power facter
watts volt amps
killawatt hr. too
and
voltage
anf hrs of operaton
and i think seen the thing for 29.99 or 39.99
power company.
