[email protected]
- Jan 1, 1970
- 0
What size of potentiometer do I need to use if I'm wanting to take a
9V battery down to anywhere from 3.5V back up to 9V?
Oh, I see. I'm regulating one led for brightness and eventually a
series of them.
series of them.
You cannot precicsly control the voltage, but all you need to do is control
current. The potentiometer can be series wired, along with a limiting resistor
for the max brightness, also in series. You ned to know the current range of
the LED, and the voltages needed for series strings. You can only use a
small number of series LED's before you run out of voltage. A 2K pot with
a 270 ohm resistor would get you going.
greg
GregS said:You cannot precicsly control the voltage, but all you need to do is
control
resistor
of
greg
No more than two inches in diameter...What size of potentiometer do I need to use if I'm wanting to take a
