SMD Electrolytics
D from BC
I was looking for a 2.2uF 100V electrolytic cap and ....there's no SMD
version available from Digikey??
Also, seems like many electrolytics are through hole.
I guess the pads probably rip off with G shock.
I've been converting throughhole components to 'quasi-SMD'. I use glue
gun glue, silicone, big pads and kinky lead bending. What a pita...
How about an adhesive under the capacitor that melts during plate
soldering? That way the capacitor is fastened to the pcb.
Wouldn't it be nice if every component were SMD?
D from BC
British Columbia
Canada.
Joerg
Vishay P/N 2222-139-69228. 2.2uF/100V SMT. Mouser carries them but 9wks
leadtime and expensive. Not for new designs but I bet Vishay has a
replacement.
http://www.vishay.com/docs/28301/139cll.pdf
Spehro Pefhany
EEV-EB2W2R2Q
Why don't you try slipping the leads through small holes in the PCB
and soldering the opposite side?
Nah.
D from BC
British Columbia
Canada.
Best regards,
Spehro Pefhany
sycochkn
D from BC
British Columbia
Canada.
http://www.niccomp.com/
aluminum 2.2uf 100vdc smt.
linnix
Is that quasi-quasi-SMD or quasi-TH? Some bean counters might charge
you double for soldering both sides. Just solder the component side.
Martin Riddle
I've noticed this also.
Since it was a supply cap, I picked the next size. You could always parallel them up.
Cheers
D from BC
Best regards,
Spehro Pefhany
Hey ...that 2.2uF EEV-EB2W2RQ is a 450V SMT electrolytic with a big
ass 10mm diameter.
A 2.2uF 100V throughhole has a 5mm diameter..
0.21 cents for the pita throughhole or $1.21 for a big ass SMT..
Huhhh...decisions decisions... :p
I wonder if there's little bases I can put on throughhole capacitors
to turn them to SMD?
Call it a SMD conversion kit..
1st solder the throughhole part to the base, then surface mount
solder.
___________
| cap |
Idea: | |
| | <throughhole cap
+========| -----|=========+ < trace from via
====+-------/ \----/ \--------+===== <smd foot
solder in this socket
Am I rich? :)
D from BC
British Columbia
Canada.
linnix
ass 10mm diameter.
solder.
___________
| cap |
Idea: | |
| | <throughhole cap
Yes, you can just feed the pins through the base and bend them
sideway. The base should be made of plastic with high melting
temperature. It should cost only pennies each, except for the first
piece.
Am I rich? :)
Yes, if you don't have to pay for the first piece.
MooseFET
D from BC said:
Really! :)
D from BC
British Columbia
Canada.
Why don't you change your circuit to use other part instead? Be flexible
like me, sometimes I can change caps, resistors, or combine the two. Do you
know the RC trick? it will save you lots of hassles. I bet Jim Crook and
his gang don't know it.
Eeyore
Some people feel EXACTLY the opposite. SMT is lousy for small runs.
Graham
Eeyore
And what about when you have components both sides ?
Graham
D from BC
Graham
I like that I don't have to drill holes and flip a board around and
around and around.
Often my designs are single layer which allows me to do hot plate
soldering.
SMD/SMT chip components are smaller for a compact design.
D from BC
British Columbia
Canada.
Eeyore
around and around.
I don't drill holes either. At least not since 30 something years ago.
Why are you making your own boards ?
Graham
Mike Harrison
Ceramics are available in this value - a bit pricy in low volumes but you may be able to find them
somewhere else with better low-volume pricing
Spehro Pefhany
ass 10mm diameter.
It'll be great if you have a lot of ripple current, which those
ratings make me suspect. What's it for anyway? Film caps could last
forever, but will be the largest way to go.
Okay, 3.3uF or 4.7uF looks to be more available (14 different part
numbers in stock). Eg. EEE-HA2A3R3P, which is 105°C-rated.
Best regards,
Spehro Pefhany
linnix
I don't either. The PCB factory does.
and flip a board around and around and around.
I don't have to solder the bottom, just solder the top (component
side).
soldering.
You can still do the same. We trim the lead to flush mount with the
PCB on the bottom, with the pins holding them in place.
Not always. Sometimes, vertical clearance is important as well.
And for the most important reason, the holes allow more precise
component placements by hand, as opposed to pick and place machines.
The components I am dealing with are too big and irregular for
machines anyway. Not until we do 10Ku, we are doing by hands.
Greg Neff
D from BC
British Columbia
Canada.
We use some SMD electrolytics in military applications. We have not
seen any mechanical problems in shake-and-bake testing or battlefield
use.
We glue the cases to the PCB after the PCB is soldered and washed,
using two-part Loctite E-20NS epoxy.
Greg Neff
VP Engineering
*Microsym* Computers Inc.
[email protected]
D from BC
Best regards,
Spehro Pefhany
8mm diameter for the EEE-HA2A3R3P SMT. Uh...maybe I'll get it.
A 5mm diameter throughhole SMD'ize still has a smaller footprint.
I'll look around. Thanks..
There's low cap self heating in the app and the ambient temp is ~40C.
The cap is doing a stabilization role. On the freaky side, I have a
case where lots of ESR is actually useful. Wide tolerance allowed too.
About that SMT electrolytic with the 450V rating..
I'll guess that cap is fat with dielectric and thin with foil. So
maybe the ripple handling is poor compared to a 100V version of the
same diameter. But just guessing without looking at the dissipation
factors on the datasheets.
D from BC
British Columbia
Canada.
