SMT Diode Identification
Arfa Daily
Michael Kennedy said:
Well there is a black stripe in the middle does that matter?
I enlarged the picture.
http://mikescomputer.homeip.net/LCD/ZD1.JPG
Is this color chart I found correct?
http://www.oldradios.co.nz/data/index5.htm
-Mike
Is that black stripe a genuine paint one on the outside of the diode, or a
"ring of fire" where it's failed ? It's right over where the actual diode
inside is. I'm assuming that it has failed short-circuit or whatever,
otherwise, you'd be able to just measure the voltage across it ?? I'd still
have money on it being 8V2 as this is such a common value. Are there no
other indicators as to what voltage it is ? Voltage that it's zenering down
from, value of series reistor, working voltage of any following
electrolytics, markings on the board of power supply voltages etc ??
The chart appears to be correct.
Arfa
Michael Kennedy
Yes I believe it is genuine paint. It is on the other diode which has not
failed.. I guess I could find out what kind of zener diode it is by testing
it as you said, but I have never done this before.. I guess it is time to
learn.
Here is a picture of the working diode (ZD2 not ZD1) up close and in the
sun so you can really see the colors..
http://mikescomputers.homeip.net/LCD/DSC00386.JPG
Close-Up
http://mikescomputers.homeip.net/LCD/ZD2.JPG
- Mike
Michael Kennedy
I was at the local surplus dealer and they had the zener diodes organized by
zener voltage. Would a 8v2 be a 8.2v zener?
Thats what I got and it seems to ohm very close to what the good zener ohms.
The actual part number for the zener that I got is 1N5237b738.
Thanks for all the help Arfa
- Mike
Peter
Zener would have failed for a reason.
If you replace it most likely the new one will go that way too.
Peter
Arfa Daily
by zener voltage. Would a 8v2 be a 8.2v zener?
ohms.
Yes, 8V2 is eight point two volts. It is the de facto way of writing it
these days - at least this side of the pond - and saves any confusion with
flies crapping on the page, or your glasses needing replacement. It is very
easy for a decimal point to disappear as a result of poor printing, or one
to appear because of that fly ...
It is also the standard way of writing resistor values - 4k7, 1M2 for 4.7k
or 1.2M ( see how easily that 4k7 could be read as 47k ). Capacitor values
appear like this too. 6u8 for 6.8uF, 2n7 for 2.7nF, 0u1 for .1uF, 3p3 for
3.3pF etc. On some schematics, you will find voltage checking points marked
in the same way.
The resistance of a zener diode, is no indication of its zener voltage,
however. There are some exceptions, but in general, any small low voltage
zener will read the same, ohms-wise, as any other, and indeed, any other
ordinary diode, because this is all that they actually are. All diodes
exhibit zener effect when reverse biased. It's just that with zeners, the
doping of the semiconductor material has been calculated to produce
predictable and accurate reverse breakdown voltages.
Arfa
Arfa Daily
Peter
In 35 years of being in this business, I don't believe I can think of more
than a very few instances where a small zener diode has failed for any
reason other than poor design of the circuit that it's in, or just chance
failure. Very occasionally, a zener is placed across a supply rail as an
overvolt protection mechanism, and will fail if that rail rises much beyond
its nominal value - because of a failed series pass transistor, perhaps -
but normally, these are large 1 watt types, that will stand going short
circuit without exploding first, not little glass surface mount types, like
the OP's example. Also, rarely, a zener in a conventional regulator driver
stage, will fail if the transistor that it's connected to, goes
collector-base short, but this is a comparitively rare failure mode for
transistors.
I think that it is highly unlikely in this particular case, that there will
be any problem, other than the diode itself.
Arfa
Michael Kennedy
I tested the good diode on a 12vdc transformer. The transformer had an
output of 16.7v and the diode "zenered" at 11.75v... so does that mean it is
a 12v zener?
- Mike
Arfa Daily
is a 12v zener?
- Mike
That would certainly indicate a 12v zener. This is another very commonly
found value.
If that is the case, then the coloured bands on this particular diode, would
seem to be meaningless. unless they are signifying a diode type that
contains the numbers " 802 " or " 208 "
or it's some kind of house code. If the voltage definitely settled at
11.75v, with a 4k7 series resistor, then the only other check that I might
do, if it was me, would be to drop the value of the series resistor to
perhaps 2k2, to increase the zener current. Sometimes, a zener will not
stabilize to its nominal rated voltage, if the zener current is too low. If
you still get around the same voltage, then you can assume that 12v is the
correct value.
Arfa
