sony kv27ts26 need to auto program, no button on tv ,no OEM. remote
The OEM. remote is long gone.There is no button under panel to add or
auto program channels. The TV works great. I can't surf past channel
61.Goes to 2 .But I can use remote to get higher channels but when I
surf channels it goes right back to 3.Any HELP out there?
Jerry G.
You need to buy an original factory remote for your set. Most all the
new sets are like that.
Jerry G.
JR North
Buy a universal remote that will access the TV's menu.
JR
tvguy
JR
Home Page:
http://www.seanet.com/~jasonrnorth[/quote:40c971efee]
Not all universal remotes will do the menu feature. You would need to
find one that is compatable to that model of tv that you have in
order to get the menu to work for it. It is like RCA tv`s and RCA
universal remotes. They may operate the tv but it wouldn`t let you do
all the features like the original remote that came with the set did.
So you are better off trying to locate the original remote for that
set.
Thanks guys,Less then 24 hrs and I got answers! Spent 2 days o-line
looking for same.Hope I can help out sometime!!!!!!!!!!
Rafterdog
Leonard Caillouet
While this is true for this set, it is not for MOST sets. In fact, Jerry,
the vast majority of sets can be reprogrammed with a universal or some form
of replacement remote because they access these functions through the menus,
which can usually be done with the rather generic button layouts on many
programmmable remotes. The old sony sets with a specific button for some
functions are an exception, not typical of "most all of the new sets."
1-800-REMOTES might have it, or maybe someone has loaded the IR signature to
a learning remote with a computer interface like a Pronto, Harmony, or
Universal. You might try remotecentral.com.
Leonard
Shoreline Electronics
Goto this website : http://www.electrosoundusa.com/ Click on the remotes
link
The Moteva remote # RC-1003 should work OK. It has the Auto Program button
( Which may or may not work....but more important the ADD & ERASE buttons
which should enable to manual add & delete channels.
All for a whopping $10.99
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
[email protected]
link
Jeff Stielau
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
[email protected]
THANKS to every one for the help!!
RAFTERDOG
