Sony KV27TS29 Sides Bow In
gymsurely
It looks like the problem is IC501 (TDA8172). Does this make sense? The
picture returns to normal if I tap the part. I'm not an electronics
person but I'm tempted to buy a part and replace it.
Ross Herbert
first, check for dry joints in the area around the IC. It might be
that simple....
Andy
and the capacitors in this area,which may have dried up
It must be some part nearby, maybe even mounted on the same aluminum
plate, but definitely not this IC. Your error is in the E/W circuit,
this IC handles vertical deflection. Most of the time the E/W regulator
transistor or some related coils will have bad solder connections.
gymsurely
I reflowed and/or added some solder on about 12 pins around the IC. All
looks well again.
b
i recall repairing a kv27ex about 3 years ago with this condition.
there was a geometry daughterboard at the rear of the main pcb which
had dry joints where it joined the main pcb. I also cleaned all the
pots on it to be sure.
hope this helps, Ben
