Sony PS-LX510 Turntable
Madness
Been working on this turntable for a bit of time. Did get a copy of the
service manual. Replaced tonearm belt, lubed rail & adjusted some of the
adjustment screws (arm height,tracking error, etc.) inside the tonearm,
itself. So, no more sticking during play. But one issue remains: rumble
being picked up when the stylus lands on the record. Being a
direct-drive, what's the fix (SM has no info)? Oil to the motor, perhaps?
N
N_Cook
have you washed out the bearing and re-lubed it? could be just hardened lube
rather than grime
Madness
rather than grime
The motor bearing? I'll take a look at it.
GregS
i don't think I ever had this problem. I know the low frequency fundamemtal resonance
of the arm/cartridge can agrivate this. To find out place the needle on the non moving
record and gently tap the record to see if there is a similar frequency sound. You could also try a record
clamp but this may actually increase rumble. A record clamp makes a huge difference on the tap test.
So whats the frequency of the rumble ?
greg
