Sony SL-C9 frame advance fault
  • Thread starter Colin McCormick
  • Start date
Colin McCormick
x-no-archive: Yes
All
I have a Sony SL-C9 with frame advance fault: Does anyone have a service
manual or info to hand which would tell me what to adjust for this
fairly minor problem on an SL-C9: The 1/10th speed, and frame advance
(including reverse) don't quite work, the picture jumps a tiny bit but
doesn't move on a frame. Also the freeze frame often has a noise bar.
But the 1/5th speed works just fine and without a noise bar. I expect
there is some adjustment required to change the nudge power for the very
slow motion operations. Any advice most appreciated.
All other functions are 100% (now that I've swapped the PSU and repaired
the usual front-loading problems).
Please copy me on any reply to [email protected]
Thanks.
Colin www.video99.co.uk
N
N Cook
Colin McCormick said:
x-no-archive: Yes
All
Thanks.
From the E (UK) suffix version of the manual
RV1 in still
RV16 and RV17 in 1/5, no mention of 1/10
Colin McCormick
Hello and thanks for your reply.
On the servo PCB at the base of the machine, I see RV001 in
the reel section. It is labeled FR SPD. Is this the RV1
you refer to? Alas adjusting it makes no difference. It
takes several stabs at the frame advance key to make it
move on a frame.
This I think implies either an electronic fault (not
unusual for a Sony of this vintage) or a tape transport
problem (but then it would affect the 1/5 speed).
I will have to try to get the relevant part of the diagram
and start fault finding down to component level.
Thanks for your help,
Colin
Colin McCormick
x-no-archive: Yes
FIXED IT!
A slight anticlockwise adjustment of RV017 "MOTOR DRIVE" on the JR-1
panel (beneath the tuner) got the 1/10th and freeze frame advance
controls working perfectly.
Colin
