Speaker overload (tweeter) protection using bulbs (repost)
Jamie
Eeyore said:
liquidator wrote:
Jamie is notorious (with me at least) for having some very odd ideas sometimes
in the electronics groups. I think he's a little bit out of touch with current
practice in this area.
Graham
LOL, yes, I must say you're correct in this statement..
Because, if you are one that dictates current practices, I
feel sorry for the rest that follows your guide lines! oh
wait, that can never happen. You just simply spit out crap
and never give any useful information that can be used in real life
applications.
You just go on, boasting your fantasy story's..
is there anything you haven't done or don't know?
I know your an old fart and most likely starting to get
senile.
http://webpages.charter.net/jamie_5"
liquidator
Eeyore said:
According to the currently accepted rules of netquette, a post that is relevant
to several groups SHOULD be cross-posted. Most certainly not multiposted.
Explain how it is off-charter in rec.audio.tech or sci.electronics.repair where
a lot of audio is discussed daily. It was a repair question after all ! And
technical.
It's not against the law to fart in an elevator- just because you CAN do
something is it a good idea?
% out of 5 of your last crossposts have started arguments.
It appears to matter not to you. one can only assume you enjoy the
arguments.
Graham, you know I don't have anything against you. But what happens when
there is a disagreement between people in two different groups is that
persons friends join in, often they don't even understand the discussion,
they are just PO'd somebody is dissing their friiend...such arguments can't
be one by anybody, and anybody who posts more than 3 times to them has way
too much time on their hands. But Usenet is full of people with too much
time on their hands. And too little knowledge.
Jamie
liquidator said:
liquidator wrote:
message
George's Pro Sound Company wrote:
the easiest way to overdrive a speaker is to use a[n] amp
larger than the speaker[']s rateing [sic]
Actually, the easiest way to overdrive a speaker is to play it at a
level
where it produces audible distortion. But as most listeners have no
idea
what distortion sounds like...
OTOH distortion does not destroy speakers, speakers are as happy to
play
distortion as clean signal
only when you exceed the heat dissipating ability of the motor do you
burn
out a speaker
clipping does not damage speakers and distortion does not damage
speakers,
its overheating and over excursion that damages speakers
distortion is one method of achieving overheating, but you can overheat
with
a spotlessly clean signal as well
Really?, I'll make sure I don't do business with you.
Btw, distortion due to amplifier saturation, even though the amp is
far belong the rating of the speaker can and does over heat the speaker
coil and thus, can terminate the life of a speaker even rated higher
than said amp.
Ahnothetr person with minimal knowledge.
George doesn't always word things the best way, but he knows a lot.
Speakers are rated for average power, over time.
Look at the area under a square wave- it is a lot larger than the area
under
a sine wave. What that means is more power for a longer time. What is
happening is the AMOUNT of power is being increased to a speaker for a
longer TIME.
Plain and simple- that is more power. It is the amout of power over time
that kills the speaker...it can only shed heat so fast, put power in
faster
than that it will burn up.
Simple..just use a bigger amp...and drive it to peak, you can blow the
speaker quickly.
Use a smaller amp, and drive it to its full power for longer, and the
speaker will blow, assuming the amp is big enough to put out that much
average power.
Either way- it is power that is the culprit. The amount of energy being
put
into the speaker...put it in faster than the speaker can sink it, you
will
have thermal failure.
It is not DC as people who skimmed one book and didn't understand it
want to
amp
all...then
conversely
all
amps
sense
What ever you do think you know as fact, must of come at a great expense
of destroying a lot of electronics.
Again showing your gross ignorance.
As a working pro I'm sure I paid more in taxes than you earned.
Welcome to the killfiles as the only total loss I've seen today.
Dont' bother replying, but your juvenile need to will make you do it anyway.
Thank you very much, and don't worry, my kill file is full of idiots
like you.
P.S.
No one person is over anyone else. Just remember, every one
can be replaced with better than what you think you are.
liquidator
practice .
Voltage and resistance practice too.As well as theory.
Since you insist on groaner puns....
Ghandi of cousre, was an Indian holy man. What is not know as much is he had
to walk everywhere, consequently building up heavy callouses on his feet.
Due to poor diet, he suffered constant ill health and bad breath.
He was a super calloused fragile mystic vexed by halitosis.
I hope that settles the matter.
liquidator
Eeyore said:
In the early days of DC coupled outputs, some amps still had a degree of
internal AC coupling or bypassing in the drive circuitry.
They could indeed 'drift' DC under prolonged overdrive.
You are spot on with that condition...but I assumed that we would be talking
about "current" amps.
I wouldn't be using any of those old amps on the job.
liquidator
Dave Plowman (News) said:
Drive an amp hard enough and that's what you effectively get, as far as
the speaker is concerned. Try taking your head out of your arse and use
that scope.
Ignorance is bliss and you are happy the way you are.
Simply, you are just plain wrong. You seem to be interested in making
yourself look worse and worse, go on about it with somebody else please.
You've sufficiently proven it to me.
Clipping isn't DC, obvious you never studied engineering. Or physics. Or
much else, it looks like.
Bye. No more time for you. Got real things to do.
Eeyore
Jamie said:
Graham, you play with toys.. you work with toys.. and as usual,
all you have left is finger pointing because you've lost what ever
you had. That is, if you had anything of value to start with other
than what you find off the backs of others.
Your knowledge of electronics is most likely gained from destroying
an untold amount of components and still to this day, you have to
scratch that bold head of yours and wonder what you did with that last
puff of smoke you allowed to escape.
You boast that your an elite in audio design, from what I've seen you
point out. A mear amateur, expert you are not!.
Answer the bloody question IDIOT !
What is a "saturated amplifier" ? You can't even use the right words.
Graham
Eeyore
liquidator said:
"Eeyore" wrote in message
Me neither. I wonder if that was part of the reason for the Flame Linear
monicker, or was it just inadequate heatsinking ?
Graham
Eeyore
liquidator said:
"Eeyore" wrote
Curious- India Pale? No I'd be interested in where the term came from...I
knew the gin and tonic came from having to drink quinine against malaria.
Indeed. India Pale Ale. It was indeed exported from Britain to India in the
days of the Raj and to be able to wiststand the long sea voyages had to contain
a fair percentage of alcohol to prevent it going off. The length of journey
also allowed it to mature nicely.
Graham
liquidator
Graham
I think you could check "all of the above"
It was designed to be light and cheap...remember, it was a home stereo
amp...it just found favor in pro use, it was never meant to be pro...
liquidator
Eeyore said:
malaria.
Perhaps Jamie should go on a long journey...
Jamie
Graham
I proved my point..
You smuck. It's time to relinquish the community
PC and let the next guest in that ward, have their turn.
You may want to look in the hall before sneaking back
to your room. I'm sure they are looking for you.
Phil Allison
"George's Pro Sound Company"
"Jamie"
I got to say Jamie, compared to you Eyesore is a Rhodes scholar, I havn't
seen anything but pure rubbish from you
** "Jamie" is actually one Maynard A. Philbrook.
Maynard is a another fuckwit radio ham, call sign: KA1LPA
Maynard makes his living as a code scribbler, he is no electronics tech.
Maynard is mentally defective as hell.
...... Phil
Eeyore
liquidator said:
"Eeyore" wrote
I remember know. You'd get a charge pump effect.
Still saw enough of them in amp racks. Usually with a pair of Boxer fans
blowing on the heatsinks.
Studiomaster's original 800B was a modified, increased power and ruggedised
version of the PL700 with the Boxer fans built in ! And before George jumps
down my throat for copying it, it was well before my time there.
Graham
Eeyore
Jamie said:
I proved my point..
You have proved NOTHING and STILL failed to answer the question posed of you several
times now and not once addressed..
Graham
