Speaker
Vedran1
Oct 2, 2003
90
Hello!
I have one old Philips radio and cassete player and I like it very much and it sounds great, but it makes big BUM when I turn it on, and is very noisy when I am adjusting volume!
How to fix it??? ???
Thanks!!!!
ante1
Jan 24, 2004
4,136
Hi Verdan,
If you have some electronics cleaning spray you can try to get some inside the volume pot. But it is better if you can get a new pot, then it would last much longer. The
JackM78
Dec 27, 2004
4
I have this same problem with a large cabinet amp. I will try this suggestion and see if it works. I think I might have to replace the reverb pot ( not sure if thats what it's called, I'm a newb)
steven2
Jan 19, 2004
1,698
sometimes those volume controlls collect dust inside them, when this happens, everytime you turn them you get noises so you can clean them out by spraying then inside with crc, the same stuff you use on a car to free up rusty bolts or rid mioster from them, use a thin straw like attachment to spray inside the volume pots, these attachments normally come with the can
prateeksikka
Jun 19, 2004
736
hi vedran!
clean the insides of the speaker i.e right from the pot to coil (magnetic)
using propanol or ether,it will be alright ;)
prateek
steven2
Jan 19, 2004
1,698
and if you accidently tare your speaker in the proccess you can repair that tare with clear nail polish , this will allso help in reduce excess vibration of the outer edges of the speaker cone if it obsorbs to much mioster. by painting the clear nail polish around the edges, it will dry and stiffen it abit
Alun
I wouldn't go over the top with the nail varnish if I were you, I can be usefull to repair small rips and tears but too much can severely reduce the bass response of the speaker making it sound very tinny, I speak from personal experience. ;D
prateeksikka
Jun 19, 2004
736
hi all!
i have almost generalized that u can clean the inner parts of any electronic device with any volatile compound.Can all of u support me?
I have even used perfume to clean my stereo recorder head.any comments?
prateek
Alun
After shave, methylated spirits, surgicla spirit, and maybe even vodka :) are are alcohol based so they're all goo for cleaning. Nail varnish remover and even viniger are good cleaners too, and of course there's just plain old washing up liquid.
I would stay away from stronger volatile chemicals like petrol, paint stripper and super glue remover,  because they can damage many plastics, petrol will disolve polystyrene and super glue remover disolves polycarbonate for example.
