Speed control motor
alkv23
Apr 29, 2005
50
Here we have alot speed control motor. Were using for 1 of our main equipment. Last week i had a problem. My speed motor control card burnt. I need help to make new control to control speed of this motor. I had attach the motor and control pix. Here the spec.
Orientel motor
usm 425-402w
25W    200V    50Hz  0.24A    1.8uF    1200r/min
I had try with potentition resistor but it burnt also, the motor is ok coz i had try with other control. Plz give idea and circuit to make tis thing run. Thanks.
ante1
Jan 24, 2004
4,138
Hi alkv,
Maybe someone can help you if you post some pictures of the circuit board and the burned parts.
Alun
How many wires does your motor have?
Before we can help you we need to know what type of motor it is.
ante1
Jan 24, 2004
4,138
Hi Alun,
The motor looks like it might have a tacho or some other kind of feedback attached to its end.
Alun
I'm thinking it might be something more complex than a normal phase/PWM controller it could be a PLL constant speed controller.
alkv23
Apr 29, 2005
50
Thanks for ur reply. Ok first the motor have 3 wire that goes inside motor and 2 wire is the behind of the motor. Im nor sure on the type or more detail. I had attach more clear pic. About the card also, i had attach but good one. The burnt card already sent out to repair.
