Speed control of exhaust fan
John Dunkley
I would be grateful for some advice on what is the most efficient way to
speed control an exhaust fan?
Not knowing much about motors, it is a 240 volt unit 0.45 amps.
JD
Phil Allison
"John Dunkley"
** A variac will likely work just fine.
So might a phase control dimmer designed to control fan motors.
........ Phil
Trevor Wilson
**Assuming the motor is a synchronous type, your chances are limited. PA's
idea of a VariacT is ideal, but expensive and bulky. I know people who have
put a lamp in parallel with the motor and used a standard light dimmer. I
can't guarantee the results, but it should work. Another good way is to
place the motor in series with a bridge rectifier (and the mains supply).
Across the DC connections of the bridge, connect a MOSFET (suitable rated
and heat sinked, of course) and vary the Gate Volts to get speed control
that way. The advantage is the motor can be varied over a very wide range.
Brian Goldsmith.
***** Wilson,you must be joking,an exhaust fan with a synchronous motor,the
mind boggles!!!
Brian Goldsmith.
K
Kr
mind boggles!!!
Brian Goldsmith.
All domestic mains powered exhaust fans I have ever seen use a simple
shaded pole AC motor.
I think a synchronous motor would be a bit over the top for an exhaust
fan :)
http://en.wikipedia.org/wiki/Shaded_pole_motor
Trevor Wilson
motor,the
mind boggles!!!
**Call it a brain fart. Of course a standard induction motor will be the
type used. My other comments and suggestions remain.
