Hi Audioguru and guys.
Could you go back a few posts please! There is a few questions that I would like for you to answer, if it is not to much trouble.
To answer Dazza’s question.
I have a mechanical speedometer. This brings about a different topic. The application I want is a unit that if I preset it to 60mph then it must switch the buzzer and LED on at that point. So in other words all above 60mph this unit must moan until I reduce speed below 60mph. Once below 60mph the warnings must stop. This is actually all I need. The Speed limit alert circuit on the website doesn’t work so I’m looking at alternatives.
BUT
As far as I know the tachometer is the only way to go as far as wireless is concerned. Once you go the speedometer way you need a fixture like a shaft that you can count the number of revolutions per minute.
This will be to expensive.
I would rather settle for a small inexpensive way to warn me of over speeding. (Something I am guilty of many times)
Audioguru
You spoke about the 4 cascaded inverters. IC1 and IC2 is not that hot. Not to forget. IC3a also has some amplification. You must move the unit back and forth and sideways in the cabin to get a proper signal. The signal I found was basically next to the wind screen. (Not a good position) The LM2917 also has some amplification in the first of it’s three parts.
If you think that the 4 cascaded inverters discussed with Alum, will work better I would rather go for that.
Give me the schematic for a decent Speed alert with a buzzer and LED warning and I will build it.
Just for interest sake:
I have rebuilt the L1, IC1 and IC2 section again. If pin 4 of IC1 is connected D1 stays lit and doesn’t pick up a signal. Once disconnected D1 goes out. It starts flashing when a signal is detected.
Pieter
