No, but i can get one if needs be ?Do you have a BNC to BNC lead.
Yes i have already done this as i have 2 sers of BNC to crock clip leadsI was going to suggest that you connect your signal generator to you scope and have a play with them trying out different setting to see what happens. This will get you accustomed to using them and to have some idea of what to expect with various setups. A BNC to BNC lead would be the easiest way to connect the two together but you could also do so using one of the BNC to Cro Clip leads and one of your Scope leads.
To an extent yesSo, you are now familiar with your sig' gen' and scope and know how to use them eh??
I will try do this ASAPRead these instruction through before acting upon them!
Take a note of all the input and output conditions for the following tests.
These tests are conducted with no output load unless otherwise stated.
1) Connect your Sig' Gen' to one of the inputs of your amp. You may have to make a suitable lead unless you can access the input connector from inside your amp'.
2) Using one of your Scope' leads Connect the input of your Scope' to the appropriate output of your amp.
3) Set the Sig' Gen' output to 1KHz sine wave to a level of 100mV.
4) Set the output of your Scope to 10V/div'.
5) Turn the amp's volume control to minimum.
6) Turn on the Amp'
7) Monitor the Scope to see if there is any output that should not be there.
8) Whilst still monitoring your Scope', gradually turn up the Amp's volume control. Check that the output is still a clean sine wave.
You may need to adjust the volts per division of you Scope' to get a full screen display.
9) The output of your amp should be a faithful reproduction of the input signal and should be symmetrical about 0V i.e. of equal magnitude above and below 0V.
10) If the output is not as it should be, take a clear picture of your scope screen and post on here.
11) If the output is clean, gradually turn up the amp's volume control until you get max output from the amp'. Max output is just as the tops and bottoms of the sine waves start to flatten off. This is known as Clipping and in normal use is a condition to be avoided.
12) Back off the volume control until you amp' is just out of clipping.
13) Make a note of the peak to peak voltage.
14) Repeat for the second channel
15) Report all of your results here.
As long as you order takeaway you're sorted![]()
