Stage Line 500W amp repair project
bikemech
Oct 23, 2014
456
The box only has 1 BNC input for the 1 probe, and 1 audio jack as the output to the soundcard/laptop,
I do have meter leads with crock clips and do have a BNC to crock clip lead
bikemech
Oct 23, 2014
456
The probes i have are said to 100Mhz , does this mean that it there capable limit?, i think i had my sig gen much higher than that
bertus
3,875
Your signal generator can generate signals upto 500 kHz.
The 100 MHz probe will have no problems.
The soundcard scope can handle signals upto 20 kHz.
Bertus
WHONOES
May 20, 2017
1,242
O.K. You should still be able to carry out the battery check I suggested. You can, as you suggested, measure the output at the headphone jack using your DMM.
bikemech
Oct 23, 2014
456
At 1:1
I get 1.402vdc
That is with the positave probe on the base of the audio jack and the negative probe on the second connection point along, the BNC to crock clips have red and black clips, i set red to + and black to --,
I am wondering if i have the connectiong reversed to the phono jack
bikemech
Oct 23, 2014
456
I currently have it wired, green to pin 3, and yellow to pin 4,
WHONOES
May 20, 2017
1,242
Ok. That's all reasonable. Your box seems to be working.
Have you tried it with you virtual scope recently?
bikemech
Oct 23, 2014
456
I think i see the issue here, with another set of headphones the computer sees the mic and lets me select it, with the lead i have cut up it does not!,
Is it possible it has something to do with the small board the MIC is attached to on the headphone lead ?
bertus
3,875
Could it be that 3 and 4 are exchanged?
When you measure the speaker between 1 and 4, 4 is the ground.
When you measure a high value between 1 and 4, 3 is the ground.
Bertus
WHONOES
May 20, 2017
1,242
Can you determine the maker of the sound card in your computer. If so we may be able to get some info on it and see where the hiatus is.
bertus
3,875
As for the scope, have a look at the attached document.
Bertus
  • DSO150_instructions(D01).pdf
