Hi yes, i know it is displaced by 1 pin, i did this purposely to show the orientationIt's always good to take a little time to consider where you are going to place you bits and pieces so that you can get them in a reasonably logical order. It can be quite irksome to have to rip everything out and start again.
The main thing to be wary of when mounting the board is that you don't cause and shorts between the tracks and the case.
I often mount strip board on screws through the bottom of the case with 2 nuts on the screw and then mount the board on top of the nuts. If you have any, a fibre or nylon washer on the underside of the board to insulate it from the nuts works well just be cognisant of the comment above.
It sounds as if you have put the IC's in the right way round. A picture would still be useful to confirm.
There is nothing to stop you taking the LED's of the board so that you can pass them through the lid. Just be very careful to get them the right way round. I suggest that you put a a mark on one side of each LED so that you can get their electrical orientation correct and just as importantly do them one at a time. It is probably worth marking the board as well to show where the connections go. You want to avoid removing and replacing them several times as the tracks will start to peel off.
Good Luck.
Edit: have just seen the picture you posted. They look to be the right way round (I will check again) but the bottom one is displaced by one hole. You need to move it up one hole.
I apreciate your explanations, and i appreciate its going to take a while for you to get to know where my knowlage is at on this project and in general, but yes keep is as simple as you can please, i would rather read your comments and instructions and think , well yeah!, than read and have to ask stupid questions and look stupid,It's always good to take a little time to consider where you are going to place you bits and pieces so that you can get them in a reasonably logical order. It can be quite irksome to have to rip everything out and start again.
Good Luck.
Also, is there something i could print out , or a program could use to make a face plate for this box with dial and LED info on it ?It's always good to take a little time to consider where you are going to place you bits and pieces so that you can get them in a reasonably logical order. It can be quite irksome to have to rip everything out and start again.
Good Luck.
It is completely counter clockwise, so at 1:1How have you got the range switch set. You need it fully counter clockwise for the circuit to be set to 1:1.
So basically connect a 1.5vdc battery to the input and use my meter to read the voltave at the headphone jack ?If yo have a single AA or AAA battery to hand, you could use it to test your box.
Call the AA battery "Test Battery"
Connect your scope lead to the input of the box.
Connect a flying lead with croc clips to the output.
Connect your DMM to the flying lead.
Set DMM to 2V range. Switch on you box.
Make sure the attenuator switch is set to 1:1.
Apply "Test Battery" to Scope lead terminals.
Observe DMM.
It should read about 1.5V.
Reverse "Test Battery" connections.
Observe DMM. It should now be of the opposite polarity to your previous test.
Edit: I should have added "Set scope lead attenuator to 1:1" at the 7th instruction.
This is confusing, i dont understand the point of this lead when i can just use my meter leads to connect where needed ?Yes. A flying lead is one that is connected at one end whilst the other can be moved around to various points. Example, Your lead with a BNC on one end and croc clips on the other. With the BNC plugged in, the croc clip end becomes the flying end hence flying lead.
