Eeyore
- Jan 1, 1970
- 0
Mr.T said:"Richard Crowley" wrote in message
Sure, if your object is to confuse people, then not spelling out exactly
what you mean is a great way to do it.
It is a good point though.
Graham
Eeyore said:There are plenty of countries where you'll find an ambient temp close to 40C.
Imagine they want CFLs too.
"Phillips"
Mr.T said:"Eeyore" wrote
I imagine they want house cooling too.
Eeyore said:Well, they *are* dimmer than conventional incandescents.
I've always found the idea that they use 1/5 the power
misleading. Those comparisons were made with 'softone'
bulbs.
You need at least a 23W CFL to match the output of a 100W
incandescent.
The table here...
http://en.wikipedia.org/wiki/Incandescent_lamp#Power
Shows a 100W incandescent providing 1700 lumens.
In comparison some new CFLs I have claim only 1100 lumens
for an 18W and 1200 lumens for a 20W.
The 11W CFLs claim 600 lumens and that makes them only
slightly brighter than a standard 40W bulb instead of
equivalent to a 60W as claimed.
I'm certainly puzzled by the +/- 28% bit !
Yes I did, maybe you missed it.
So true!
Your name calling does not make you the sole person responsible for setting
discussion parameters on Usenet.
When *I* make a choice, I do not eliminate the best options just because
they don't suit YOUR arguments.
MrT.
Yikes!
In general, CFL lamps operate at somewhere between 23 and 29% of the
power requirements of an incandescent for the same average output in
lumens. Most that I use operate at 28%. So, I picked that figure.
But you said +/- 28%. That means between 72% and 128%.
d
The future in lighting is LED's. They are already working on halogen MSRArny said:My searching finds ordinary 40 watt bulbs rated at from 280 to 355 lumens.
More lumens at a given wattage rating generally means a shorter life. IME
incadescent lights draw significantly less than their rated power, so their
light output may also be less than spec.
280 to 355 lumens is about half the light output of a 11 watt CFL. BTW, my
experience with CFLs pretty well matches the lumen output levels that you've
mentioned, Graham.
About twice the brightness from about one quarter the power works for me!
We've seen vastly improved bulb life, which is especially helpful when bulbs
are located where they are hard to replace, such as at the top of a 3-story
stairwell.
My first project was in a large basement room that was frying about one
halogen bulb (of 32) per week, partially due to overheated fixtures. We
pretty much relamped the room almost twice a year. We put in 2 CFL bulbs
per fixture and still dropped the fixture's internal temperature to under
110 degrees F from more like 140. Lumen output per fixture almost tripled.
We were also able to get a more pleasing color temperature. This room is has
been relamped for about 3 years. We are currently replacing about one bulb
per year.
on halogen MSR replacements with LED's.
LED technology
has come a long way in the last 5 years on high output
units and modules.
Most truck trailers and even traffic lights are going to LED units now.
LED lighting
may not displace florescent's, but it will be used right
along side them in some applications.
I am also convinced that an occasional use lamps in a
closet or such won't cost justify CFL conversion. Its false economy if
it takes 40 years to cost benefit from it.
I am also convinced that an occasional use lamps in a closet or such
won't cost justify CFL conversion. Its false economy if it takes 40
Issues with LEDs today:
Color rendering
Diffusion
Once those are solved effectively, they will be excellent
alternatives. My guess is 5 years to color rendering, and 5 more to
diffusion. Most LEDs today filter a single color to a specific
monochromatic output. Even the LED-type flashlights are very heavily
skewed to the blue end of the spectrum in order to get sufficient
brightness, and require multiple LEDs to get even a minor beam with
very poor diffusion.
Albert Manfredi said:But you can use a combination of red, green, and blue high intensity LEDs,
to create any variant of "white" that you prefer. From what Ive read so
far, the efficiency of the new high intensity LEDs is almost identical now
to that of CFLs, which means about the same lumens for 1/4 or 1/5th the
power of an equally bright incandescent bulb.
I think we shouldn't get stuck on any supposed problem with CFLs, as if
they are the only alternative here.
The weird thing about LEDs is that they would last such a long time that
they wouldn't need replacement. In principle, you can build them right
into the lamp itself. Or in walls, or whatever.
Bert
Currently, white LEDs are in fact blue LEDs coated with a fluorescentThe length of service issue with LEDs is very dependant on the way they are
driven, if you are to get the maximum of 100,000 hours plus out of them.
However, that said, even if not driven properly - ie not pulsed - from what
I have read, they are still good for 40k hours, before the light output has
dropped by 50%. As far as colour rendering goes, I agree that this can be
achieved with combinations of RGB LEDs, and I'm sure can be made as good or
better now, as CFLs are ( not that I'm saying theat CFLs are good of course
... !) Just a few days ago, I saw somewhere that one of the manufacturers
has come up with LED chips bonded to a sort of 'ball on a stick' shape, so
many small chips face in virtually every direction around a sphere, to get
over the point-source poor beamwidth issue.
BTW, Philips CFLs = China ? Not any more, it would seem. I picked one up in
the supermarket tonight to have a look. It said " Made in Poland " ...
Arfa
Don Pearce said:Currently, white LEDs are in fact blue LEDs coated with a fluorescent
substance, so probably the overall light quality will be quite similar
to CFL.
d
http://members.shaw.ca/sagelighting/led_spotlights_and_bulbs_specifi.htmIssues with LEDs today:
Color rendering
Diffusion
Peter Wieck
Wyncote, PA
to CFL.
LEDs, to create any variant of "white" that you prefer. From what
Ive read so far, the efficiency of the new high intensity LEDs is
almost identical now to that of CFLs, which means about the same
lumens for 1/4 or 1/5th the power of an equally bright incandescent
bulb.
that they wouldn't need replacement. In principle, you can build
them right into the lamp itself. Or in walls, or whatever.
