Sturdy DC power jack
Hexlee
Dec 10, 2022
Hi all. Im building a saber with a plug in battery, however any impact causes a circuit break at the Jack. The Jack Is firmly in place and well connected but it still persists.
I suspect the negative contact inside the female is not enough to maintain a constant contact when it’s jolted. Is there a power Jack that has a larger or ideally full 360 degree negative coverage inside the female ? F8632633-1714-461B-A12B-FA3B5AE9EB4E.jpeg
Try the range of dc battery connectors as used in R/c gear.
XT30 for example....some are available with leads already fitted.
Externet
Aug 24, 2009
944
Consider XLR connectors too.
There is four pins type also to ensure redundance, and bulkhead. Same with speakon connectors. Perhaps you can use simple RCA type too.
14,487
Or a common connector type for DC power is this SAE connector ... on all out commercial
stuff we sell
