superconducting wire questions
K
Ken Williams
If I have a normal copper wire and I run electricity through it a
magnetic field is produced around the wire.
1) If the wire is super conducting there should be no magnetic field
correct?
2) Is the magnetic field produced in a copper wire proportional to the
wire's resistance somehow?
Charles
Ken Williams said:
If I have a normal copper wire and I run electricity through it a magnetic
correct?
Super conductors are used in accelerators and they have an awesome magnetic
field. Resistance limits current flow which limits the field intensity.
Sjouke Burry
correct? NO
NO
Bob Myers
correct?
No and no. The magnetic field surrounding a conductor -
or even that due to a stream of electrons in free space - is
proportional to the current, which simply put is the amount of
charge "flowing" past a given point per unit time. In other
words, the magnetic field is proportional to the rate at which
charge is being transferred along a given path.
A superconducting wire carrying, say, 1A of current would
have exactly the same field surrounding it as a conventional
conductor carrying the same current. What it would lack,
due to the lack of resistance in the conductor, is a *voltage*
drop from end to end.
Bob M.
