With the counter balenced swinging arm sitting on the pivot needle ,with its magnetic needle sitting midway inside the contact coil switch it on. any magnetic feilds or ground vibrations like an earth quake can set it off. once the detector goes off it will continue sounding till you switch it off and reset the detector so the needle is set in middle position through the contact coil without touching it, then switch it back on again. the electronics section is housed at the narrow end of the detector plattform it is afixed to ,this is made of wood in a near long tryangle shape , so that the electronics section is at a reasonable distance from the swinging arm peace. it runs off a nine volts battery.
by Steven
by Steven
