Hi all,
I thought about building a power supply for a thermoelectric (peltier) cooler element, which maximum power is 122W @ 15,7V (~7,8A).
I have a toroidal transformer whose ratings are 300VA and 2x35VAC, so dropping the voltage from about 40VDC (or something, I don't know the exact voltage which comes from the transformer after rectifying&filtering) to around 12-14 volts would most propably produce tremendous amount of heat to the linear pass transistor(s)... (40V-13V) * 6,5A = 175,5 W of heat if i calculate correctly. That could make good heater though
So I started planning a switching power supply. TL494 might be good choice as a controller IC, so i downloaded the datasheet and started designing with EAGLE...
Only problem is that the circuit presented in the datasheet has output voltage of +5VDC and current capability of 200mA.
I understand that the output voltage and current are both "sensed" by the TL494's on-board operational amplifiers, which control the PWM "chopping" process... changing resistor values might do the trick!
I think that by changing the resistor values, switching transistor, output coil, capacitors and the current sense resistor would solve my problem.
Would someone give me some advice ???
TL494's page: http://www.onsemi.com/site/products/summary/0,4450,TL494,00.html
