Switching power supply
audioguru2
Apr 6, 2004
12,026
Hi Ante,
Sorry I didn't notice that your transistors are darlingtons. They don't look like darlingtons.
In a half-wave charge pump the transistors must conduct twice the load current, right?
For your 2.5A load, each darlington conducts 5A and its max saturation voltage is 2V. Therefore their max dissipation is 10W each for half the time which averages to 5W each continuously. Your darlingtons were probably better than minimum spec, and you were lucky. ;D
ante1
Jan 24, 2004
4,138
Hi Audioguru,
Yes, I might have been lucky. Don’t you think the minimum specs are very rare? I think so because the manufacturers like to have a good margin to play with! Can you honestly say you have ever found any semiconductor with minimum spec? Well I haven’t not even close to minimum! Maybe back in the germanium days, when I built my first variable bench psu with an AD149 on the back! ;D  ;D
audioguru2
Apr 6, 2004
12,026
Hi Ante,
I always design circuits using manufacturers' guaranteed minimum specs and everything works fine. ;D
I also still have my very first psu that has a BDY38 (I have its 1968 datasheet) silicon transistor replacing its original germanium AD149. I can hardly read the label on it since it is badly pitted from zapping shorted Ni-Cads. ;D
ante1
Jan 24, 2004
4,138
Hi Audioguru,
I agree, caution is a virtue (better safe than sorry)! And I am sorry to have confused you with the wrong transistor symbols. At the time when I converted the old doodle to this drawing I couldn’t find the correct symbol for a darlington. Unfortunately I have lost my old psu along the way, 35 years is a long time for any psu! I still got my number two psu though; it has a 2SD92 on the back 0-20V@1A! :eek:
Alun,
Yes why not, go ahead make it more up to date and efficient!
jasssam
Mar 11, 2006
10
Good day every body
I would like circuit Switching power supply which use IC LM2575
http://www.elec-micro.com/electronics--project--Swictching%20regulator.html
engrmAsif
Jan 29, 2007
Hi
i m new on the forum.
but old for electronics.
i think u should change the resistor with a high power resiter.
its easy .................
bridgewater
Jun 18, 2010
=Underdog=
Hello
I'm new to this board and My name is Peter, I found this thread in the google search engine, while searching something and I found this community and sounds  interesting.
Hopefully I can contribute something to the community though.
Wow nice,,, Thanks for sharing your knowledge Guys... God Bless
