Tacx T2240 turbo trainer - blown resistor
DaveNicko
Oct 28, 2019
5
Hi all,
I hope you don't mind a first post from me asking for help! I have a turbo trainer which I believed to be out of warranty (it is almost two years old). Apparently it is not, but I am having trouble finding the receipt so may have to attempt a repair.
The attached photo shows the problem - a blown resistor (R64). If I cannot source the receipt, I will try and fix this myself (though I recognise the problem may be more than just this component) but wondered if you people could offer any advise!
The trainer is a Tacx Flow T2240, and the unit receives no power when plugged in (and switched on!). You can see in the picture that the resistor is right next to the mains power input, and could therefore be acting as a fuse to protect the rest of the circuitry.
I did find inside the unit a small piece of metal which looks like it has broken off somewhere, but it doesn't seem to be from any part of the trainer and presumably entered the unit on assembly. It may be that this piece of metal is the cause of the problem.
Any advice welcomed!
14,317
You may have a point here. However, without a schematic or at least a reference board it is next to impossible to say which replacement componnet should go there.
14,487
There's already a proper fuse there on the lower right of the power socket
This power input area looks more like one of those nasty transformerless mains to DC power convertors
DaveNicko
Oct 28, 2019
5
Thanks both for your replies.
I suspect that davenn is correct regarding an AC to DC converter - I am trying to source a replacement and will post a pic here of the working component...
Thanks for your help!
73's de Edd
Aug 21, 2015
3,730
Sir DaveNicko . . . . .
Am I correct in my consumption that I have found the correct portion of the affected unit, in the respect of it being the braking unit with its related
solenoids working against the steel geared wheel for creating system braking action ?.
With the associated electronics aspect, being its variable adjustable power supply, feeding to those solenoids for mag braking.
The equiipments other portion that I saw and surmised an evaluation . . . . . seems to have been a generator type of electromechanical contriviance
that used adjustable loading to it, to maintain a variable / adjustable degree of restraint, for creating a physical workout to the biker.
RELEVANT R64 RESISTOR . . . . .
By my blow up, above.
That resistor looks like its having 2 copper caps with silver overplating, as you can see by the timely blackened AgO2 onset. The resistor body core is being a ceramic bisque, blank rod.
Then it is having the connection to each cap of a nichrome resistance wire . . . . being RED marked just beside them . . . . that has the bulk of the wire left intact on its "64" side. Considering that nichrome is being a quite tough and springy wire, it just might have compressed back towards that half, after burning open at its weakest point, from current overloading.
If you examine nearby, there is a white rectangular 1 amp time delay fuse marked as T1, it should be positioned / wired into the AC line input power on the "hot" side. Ohm it out as being a shorted circuit, if its being good and not blown.
I must waiver . . . without any further info or closer examination . . . . . as if your opened resistor might not have been inserted in circuit on the complete opposite side of the AC power cicuitry loop , being in line at the neutral side return of the power line.
There, the voltage developed across it is being relevant to the power consumption thru it, and that voltage level would be used as a control input for monitoring and for corrective power parameter shifting.
If that was my NUT to crack, I would see if I could get two test wire leads with their clips on each end, connected to the two end caps of the resistor. The leads other clip ends get connected to a DVM or even analog ohmmeter.
Then I use a set of small tweezers to see if I can manipulate the two burnt apart inner ends to touch just long enough to get an intact resistance reading, some scraping away of oxide may be needed at the nichrome inner wire tips.
One aspect of analysis, that you will presently be able to do, is to plug in your AC power cord in to the unit but NOT into the AC power line and then make one ohmmeter lead contact to one of the blades / pins of the male power plug and the other
ohmmeter lead is connected to one corner connection of the white F1 fuse. Is the ohmetter then confirming that there is a direct connection being made ?
If not , then try the other possibility of moving the ohmmeter lead to the OTHER pin of the male plug and do the same test to the fuse, with the other lead.
One of those connections should be directly connected to the fuse. THEN you will be able to use the OTHER unconnected male connection to receive the ohmmeter lead and then use the other ohmmeter lead to see if that connection is being made to either of the leads of the R64 problem resistor.
That test should reveal if the resisror is being conected to the "cold" side of the AC line as was earlier surmised..
If there is being no connection, then we just might expect that the R64 resistor is possibly being used at one end of another supply that is being an adjustable DC supply, being in the order of 24VDC that, is feeding those solenoid braking coils.
From an UL Underwriteres safety aspect, I can see that DC supply needing to be derived from a "cold " . . . . AC line isolated source . . . . . such as using a switch mode power supply with an ISOLATED secondary winding for producing that variable DC.
Can you give closeup pictures of that boards topside components, so that we can figure out what is REALLY being done, design wise ? Later on, the foil side, to see the wiring interconnects. The present pic only shows a portion of the top side.
73's de Edd . . . . .
Now . . . for some thoroughly fascinating medical news:
It was recently discovered that lab research causes cancer in rats.
Peathaugh
Dec 4, 2019
9
Evening, I have exactly the same problem with my turbo trainer (a TACX Smart Flow T2240). Two weeks ago its was working fine. It then sat in the spare room for 2 weeks doing nothing. When I went to use it there was no response to switching on power supply, no light at all. I took it apart this evening and noticed a small piece of material dropped out. It appears to be half of the now broken insulating material around a resistor (??). Its the same component that you have identified as a likely issue.
Did you ever get a resolution to this problem ?
73's de Edd
Aug 21, 2015
3,730
Sir Peathaugh . . . . .
Doesn't look like the party of the first party . . . thrice removed . . . has ever come back to the situation.
In a further and deeper examining of the photo that he submitted . . . . . .
Looks like you found one of the small ringlets that had opened up in the winding of that R64 wirewound resistor . . .a fusible resistor, that is. . . . . and it definitely HAS fused out.
With it initially starting out with maybe 15 turns around its ceramic core, then blasted by overload to now having a mere half or so of its turns missing and a resultant open circuit.
So I would consider it as being in series with the hot line of the AC power coming in, that looms so ominously as that black connector at the top right front of the photo . . . . . there must be a dead shorted component in that systems supply area.
img_20191019_102945-jpg.46333
OBSERVATIONS . . . . .
Close side of the BLACK AC connector is a Matsushita surge varistor and 1 A ceramic block fuse.
Foreground has a D5 MELF type of diode and another at on the far right side rear of the BLACK AC connector and yet another at the large hole in the PCB..
And MOST importantly, is the DF10 4 pin FWB rectifier off the top of the connector. So power comes in and gets rectified by that DF10 bridge to supply the two Black electrolytics at the bottom of the board, for the basic raw DC for the supply.
With no blown T1A fuse all might be well with the DC power supply
Rest of the board . . . .
Top left corner is a 4 pin optical isolator, verifying this frontal area as being an AC "HOT" area, while thedeep, far side of the O.I. is a cold supply connected area.
Now where I think that your problem area . . .really . . . REALLY . . . .REALLY is being is the ST branded triac , between the two close in silver Torx screws.
There is also a series SM sampling resistor of 3.3 ohms connected off its MT1 or MT2 connection.
Which ties into a like other parts situation . . . . look to the top of the photo . . . . where another SM 3.3 resides, with probably yet another (grossly out of focus) power semiconductor up there . ( Is it same-same Triac? )
Read the ST's top line and confirm if that unit(s) is being a BT 200 series of triac . . . .feedback to us, all of its marking.
PROCEDURE . . . . .
Take DVM in hand and place in OHMS mode and lowest OHMS range ( unless autoranging) and ohm out between all of the 3 pin combinations of the assigned T1 triac.
Your AC power coming into this . . . . probably shorted . . .Triac apparently passes thru the already blown open R64 fuse resistor.
Now . . . . . GODOITTOIT . . . .
True Diplomacy is the ability to tell someone to "get lost" in such a way that they look forward to the trip.
DaveNicko
Oct 28, 2019
5
Hi all,
Apologies for not getting back to you all. And thank you for the effort - it is very much appreciated!
I thankfully received a new unit under warranty and have taken a picture of the offending resistor. It turns out it is a 2W27ΩJ resistor also labelled as CGS. The black cover looks suspiciously like the piece of black metal that fell out of the unit initially.
The picture fails to upload on my phone, but I will try and upload it later so you can see, and for future reference.
Thanks again
DaveNicko
Oct 28, 2019
5
Here is the picture.
Turns out the filesize was possibly too big.
Peathaugh
Dec 4, 2019
9
OK, more information. It seems to be a MOSFET (metal–oxide–semiconductor field-effect transistor) that is at fault. Finding out more info tomorrow from my expert friend.
Peathaugh
Dec 4, 2019
9
A small update. I managed to source a replacement MOSFET via eBay (2 for £8). I have handed these parts and the turbo back to my expert. He has it now to attempt repair. I'll let you know what comes of this once he gets back to me.
DaveNicko
Oct 28, 2019
5
Great stuff.
Let us know how it goes!
Presumably the component that went on your unit is different to the one that went on mine?
Peathaugh
Dec 4, 2019
9
Eh, no. Exact same resistor failed, but it is thought that it was because of a failure of another component (the MOSFET). Hope is that by replacing both components that it will work again, but there may be other parts that failed also. Its a bit try and see at the moment.
Ironmanchris2018
Apr 27, 2020
Hi, my tacx has exactly the same fault, I can see the resistor that is pictured has definitely blown on mine, what parts did you change and did it fix the fault?
Ironmanchris2018
Apr 27, 2020
Hi did you ever get this repaired successfully? I'm desperate for a cheap fix for mine
Lmsh201
Apr 29, 2020
Hi there, can I ask how you managed to remove the casing over the electronics? I’ve managed to remove the cassette and outer shell but not able to uncover the circuit...
Many thanks for your help, I think I have had exactly the same problem.
I hope to have a go if I can access it and feedback how this goes.
Chamberlain111
Apr 28, 2020
To get it apart you have to pop the plastic grill above the little fan off and unscrew the screw in the middle of the fan.
Ive has the same problem with my unit with the same blown resistor. I’ve ordered a 220kOhm resistor to try replacing the blown one with, does anyone have any advice if this will or will not work / is a bad idea?
Angers
May 5, 2020
4
Hi, I appear to have the same issue. Keen to know if a solution was found either through a new resistor or support from Garmin. Cheers
Peathaugh
Dec 4, 2019
9
Evening folks. No news yet on my electronics expert mate who still has my unit to try to repair. As a recap, the blown resistor seems to have been a result of another component failure (a MOSFET - yeah I know !!). I sourced replacement parts and gave them to mate. I'm not hassling him for a result as he is doing me a favour. Once I get some feedback, I'll update here and try and let you know what was done in some detail. As for TACX/Garmin support, no joy for me as the unit was second hand. If you have proof of purchase you might get somewhere. Otherwise, quoted about £180, effectively buy a new one ! My fingers are crossed !
