turbo jet fan [DYI] - feedback appreciated.
cyberdog
May 18, 2025
I decided to build turbo jet fan (enclosed), with a lot of help from chatGPT.
Can you help me with feedback on this one?
LiPo batteries are expensive and hard to integrate in smaller form factor.
Motor is bit too powerful, but I can dial it down.
I am looking for feedback compatibility of component and safety.
components:
- motor + ESC + controller; 40mm=460W MAX in 16,8V; 29,8A, working voltage 7.4-16.8V
https://www.aliexpress.com/item/1005006184419940.html
- battery 4x Samsung 21700 INR21700-45T Li-Ion 3.6 V 4500 mAh 50 A
- BMS
https://techfun.sk/produkt/bms-modul-pre-litiove-baterie-3s-4s-5s-100a/
- Charging board
https://www.aliexpress.com/item/100...V5Vlpn9m&utparam-url=scene:search|query_from:
- battery indication
https://www.aliexpress.com/item/1005005727166588.html
-amp meter
https://www.toolkitrc.com/product/wm150/
-nickel strips 0,2mm x 10mm (6 layers between each battery connection - spot welded)
-copper strip 0.2x10mm alternative for 6L nickel (sandwich of nickel (bottom), solder(center), copper(top) spot welded on battery)
-XT60 connectors
-21700 Battery Terminal Insulator Rings
-heat shrink tubing
-Kapton tape
-car fuse 40 amp
-Balancer connector (JST-XH 5-pin (male +female)
-case 3D printed by friend
-High-temp silicone rubber cable (e.g. 200 °C rated)
[somehow in metric part of this world the silicone cables are also categorized by "AWG" size]
wired connection Current Wire Size (mm²)
Battery to ESC ~30–50A 4.0 mm²
ESC to Motor ~30A 2.5 – 4.0 mm²
Charging leads ~5–10A 1.0 – 1.5 mm²
Balance wires <1A 0.14 – 0.25 mm²
wiring scheme straight out of chatGPT:
the last image is little bit "sus"
crutschow
May 7, 2021
991
What is a "turbo jet fan (enclosed)"?
shipnever
Nov 15, 2025
[mod edit: removed unnecessary quote of complete prior thread]
Building a turbo jet fan sounds fascinating! Considering the challenges with LiPo batteries and motor power, have you explored alternative battery options? Safety is crucial; maybe adding thermal protection could enhance it. By the way, have you checked out of this?
poormystic
Jul 23, 2023
187
It looks like the op wants to make a ridiculously powerful, handheld wind generator - on YouTube I saw one that could blow the water out of a hand basin!
If it were me I'd look at model aircraft gear.
