Taser display sign Serial number 0911000118
patk
May 2, 2012
We are a small Cincinnati Police Museum. We were given as a donation a Taser Display
Sign Serial number 0911000118. It runs just fine. It does have an on and off switch. Our problem is that is does not turn off. Any ideas?
Check the switch and make sure it's actually working. Sounds like it isn't -- at least that's the simplest explanation.
shrtrnd
Jan 15, 2010
3,902
Somebody might have wired around the switch if it was already broken.
If it's just the switch, like *steve* said, you just need to replace it.
If somebody wired around the switch, install a replacement switch.
There should be somebody, if you ask around there, who should be able to help
you with this, it does sound like a simple problem.
