TDA1554 Melting
adamdavies986
Feb 10, 2017
13
Thank you very much, I will finish the new PCB tommorow and post a picture of the design.
14,479
photo it with good lighting and sharp focussing from directly above BEFORE you mount any components
and you really need to sort out the input situation
73's de Edd
Aug 21, 2015
3,730
.Sir adamdavies986 . . . . . . . . the 1st
If you were able to fry one of those units, then I guess that unit doesnt have as good of a thermal shutdown and cutoff /protective features as its old grandfather 1875 series did.
I usually just like to refer to application notes from the IC manufacturer, where they have built up test prototype units , and I then just use their PCB layouts . . . . seems like Philips made none and since being acquired by NXP as their new Daddy Warbucks, he is certainly going to worry about the past.
Probably more likely he is going to declare . . . . Not For New Design. . . . . and quantum leap shift to present audio Class D digital design technology.
Here is a MORE direct foil layout path of a TDA 1554Q build . . . . . . that has been around since ~ 2011.
I only question its smaller foil eyelets draw in choices , making the necessity of dressing some component wire lead length along and coincident with the adjunct foil path.
Also I would shoot the rear speaker output leads straight back . . . . enough to clear the heat sink fins.
That would then leave that further back foil area, a to build your regulator and USB connector on.
FULL REFERENCING at . . . . .
HOT LINK https://3shared.wordpress.com/2011/08/12/tda1554q-22w22w-bridged-chip-amp/
PCB FOIL SNIPPET . . . . .
73s de Edd
adamdavies986
Feb 10, 2017
13
Here is my new design, it is now 22cm square smaller. The group of 9 pads at the bottom is the audio input connected to a potentiometer and although the speaker outputs are near the IC, they will not be covered by the heat sink. I will be unable to make and test it until next week
adamdavies986
Feb 10, 2017
13
The resistor between signal ground and power ground will be 100K to reduce interference from the Bluetooth
73's de Edd
Aug 21, 2015
3,730
MUCH mo' better . . . . . . but don't the main filter capacitor foils need to be extended out a bit more, in order to make physical clearance from the heatsink fins on the component side ?
By all means, leave the companion HF bypassing ceramic cap up nearby the chip, as you have it , just mount the ceramic capacitor proper on the foil side.
As for that last mention resistor incorporation, just install it, and then on a shakedown . . . . evaluate and then jumper across it, to see if it was of any consequence in the circuit application.
