TDA1554 Two Channel Audio Amp Chip
Mukhalled
Aug 17, 2004
137
Hi
Is there another IC to use instead of (TDA1554 Two Channel Audio Amp Chip) in this project?http://www.electronics-lab.com/projects/audio/006/index.html
Because I can not find this IC in the electronics shop.
I need your help my friends ;)
ante1
Jan 24, 2004
4,138
Hi Mukhalled,
If you do not attempt to use the four-channel configuration you could take a look at TDA1552, TDA1557 or TDA 1558 instead. These are all 2 X 22W.
Perhaps you can get one of these in the electronics shop.
I hope this helps. ;D
Mukhalled
Aug 17, 2004
137
Thank you ;D , but should I do some changes in the curuit if I chose another IC like you mentioned ( TDA15 52, 57 or 58)? ;D
ante1
Jan 24, 2004
4,138
They are very much alike, you can download their datasheets here: http://www.datasheetcatalog.com to compare the different options included. So, was it possible to get one of these at your electronics shop?
