Testing car battery
dxpwny
Jul 9, 2011
30
I am working on a project that requires 12VDC and at least 20 Amps - for maybe 20 seconds, three times a day. The idea of using a used car battery occurred to me. If I look to by a used one, how should I test it ?
If I go this route, would it be fine to trickle charge it continuously - maybe connecting a power supply set to about ~13 or 14 V ? Would it be ok to just put a diode in series with the + lead so as to prevent battery current from flowing back into the power supply ?
Gryd3
Jun 25, 2014
4,098
Don't rely on a 'voltage' to trickle charge a battery.
Batteries are charged with a 'current', now... the relationship between the two is a direct relationship... so a higher voltage will be a higher current... but if the batteries voltage is too low, then the voltage you connect to it would result in a higher than desired current flowing.
That said, it is perfectly safe to set, and leave a trickle charger on a Lead Acid battery for prolonged periods of time.
A diode would be helpful... but only when the power supply voltage is lower than the battery and this could happen in one of two ways:
Someone unplugs the power supply (oops!)
Or whatever you are powering with the Battery feeds back with a voltage spike.
As far as testing is concerned... It may be best if you can find a family or friend in a car shop. They have a battery tester that will load the battery to see how it responds.
If you test it yourself, you will need to actually pull 10-20A out of it while you measure the voltage. If the voltage drops too low, the battery is no good. Shop are already setup with this.. See if you can call in a favour.
duke37
Jan 9, 2011
5,364
Burglar alarms often use a 12V battery and have a power supply which is set to 13.8V. They are safe to work without the mains connected and will not discharge the battery in this condition.
The 13.8V is chosen to be suitable for the temperature in the UK. You will need to find out the voltage necessary in your country if the temperature is significantly different.
One which I have contains a 7812 regulator boosted to 13.8V.
