The correct place to insert a temperature sensor?
Enrico1
Sep 1, 2010
4
During the process of building my own dual-variable power supply, I decided to mount a cooling fan, controlled by a lm35 temperature sensor, to cool off the heat produced by the numerous of components.
Inside my box (old ammo case from WW2) there is very little space:
- 2 backlit displays (2x16 char)
- 1 Toroidal transformer 50 VA
- 1 Toroidal transformer 225 VA
- A total of 4 "TO220" voltage regulators (2x 7805, 1x 7905, 1x 7812) each one with it's fellow heatsink.
- A big heatsink where 2 LM338TK  (TO3) are mounted, this heatsink is mounted partly inside the case, partly outside.
I placed a 120 mm cooling fan driven by a PIC - LM35 based system.
My question is:
Where is the correct and most efficient place to put the LM35 sensor?
I thought about the big heatsink, but it will be tiepid most of the time, because of its size and the fact that it is, in part, outside the case.
I thought about the 220 VA Toroidal transformer, it should produce some heat under load.
I even noticed that the various LM7xx that populates my utility pcbs are often very warm (especially the lm7805 that powers the two displays, 3 pic and some leds).
I couldn't give myself a satisfying answer
Hero999
Oct 28, 2007
2,433
Connect the power supply to the full load current at the lowest voltage and measure the temperatures of various components. Put the sensor near the warmest device.
I wouldn't expect the transformer to get very hot, it'll be one of the voltage regulators. You shouldn't need any over temperature protection as the regulators have built-in thermal shut down but if you want to turn on a fan when it's too hot, it's probably a good idea.
