Jasen Betts
- Jan 1, 1970
- 0
Exactly why do you think car's *aren't* fitted with skinny tyres ?
so they can give a good ride with mediocre suspension.
Bye.
Jasen
I would suspect greater tread area and lower ratio of vehicle weight to
tread area would increase the life of the tread.
If there was not a significant disadvantage of skinny tires (with
higher pressure), then I would think cars would be using them to get the
tire weight down.
So you drove 70 mph between fillups?
V8 hybrids ? Don't be so ridiculous.
If US auto makers don't change their ways soon, they'll be out of
business.
Graham
Yep, I think the small batteries and electric motor in the Prius
are there for only 2 reasons..
1) efficency gained by regenerative braking
2) improve the acceleration so the ICE can be smaller also
improving the efficency.
If you had the small ICE without the acceleration boost provided
by
the electrics, the acceleration would be poor and people would
not like the "drivablility".
Intersting to note that a flywheel could provide the same
advantage.
In fact I tend to think of the battery and electric motor in the
Prius is just an electric implementation of a flywheel.
Mark
Mark
no matter - as long at their axles are rigidly constrained to
point in the exact same direction and the have equal and opposite
rotational momentum.
Bye.
Jasen
DRAG was from the theater when all parts were performed by
males. It
meant: 'DRessed As Girl' The other parts were DRAB, or "DRessed
As
Boy' I worked the stage crew on plays in high school, and the
drama teacher couldn't let a day go by without dumping a lot of
theatrical
history on us, while we were working on the play. BTW, I was the
sound man.
So, if you want to keep her in dresses you DO want her in drag.
Service to my country? Been there, Done that, and I've got my
DD214 to prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Most of us don't have three phase outlets and it is expensive to
get.
The twelve hours is from a source you'd have at home. Cross
country would be a problem - long extension cords and very
accommodating motel owners.
One alternative to a different class of electrical service might
be super caps or storage batteries that could sip electricity all
day long then pass it to the car in one big gulp.
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure
Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup
Service in the World! 120,000+ Newsgroups ----= East and
West-Coast Server Farms - Total Privacy via Encryption =----
JosephKK said:Michael A. Terrell [email protected] posted to
sci.electronics.design:
Thank you sir for explaining that to me.
JosephKK said:
Rich said:I won "designated driver" one time, and drove this guy's Mercedes 300D.
What a pig! Had horrendous blind spots, and went 0-60 in about 10 minutes. ;-)
Mark [email protected] posted to sci.electronics.design:
Yes, and flywheels bring their own issues with changes yaw, pitch
and roll. There will have to be space for the flywheel to spin not
only during normal driving but the vehicle must not become a hazard
if it rolls over in any direction or spins out.
MooseFET said:I think compressed air is a better way to go.
Don said:Go for what?
The energy density of compressed air is ludicrously low.
Typically one sixth of lead acid or worse. 15 wh/l is hard to acheive.
The efficiencies of most compressed air motors are much worse than an
ICE. Typically 29 percent or less.
No means of efficiently compressing air is known.
Efficient compression requires isothermal operation, which can only be
approximated by elaborate and costly multi-staging.
The fire service proved all this a century ago after throwing bunches of
engineering at the proglem.
The ONLY thing compressed air has going for it is shop floor
convenience. Hydraulics immediately get substituted when serious tail
twisting or anything remotely approaching efficiency is needed.
Guy said:The ONLY thing?
There are other advantages. With pneumatics the light-load
cycle rate is higher, the piping for distribution doesn't
need to have a return path, and in some clean-room applications
the system can tolerate traces of ultrapure gas leaking into
the working area, but not any sort of liquid.
Hydraulics win for strength, efficiency, positional control,
stiffness, and safety if a pipe or cylinder bursts.
You will never see pneumatics in a bulldozer, and you will
never see hydraulics in a machine that puts CDs into CD
cases. Having worked as a design engineer for both Parker
Hydraulics and SMC Pnuematics, I don't see either of them
cutting into the other's business.
Compressed air power storage is horribly lossy.
Graham
It was likely a combination of coincidence and something very wrong
with the car. 22MPG at 55MPH is a horrid milage. This is very like
the leaky fuel line case.
