John Larkin
- Jan 1, 1970
- 0
John, I neglected to leave out the type of fuel cell generator just toJohn said:That's interesting.
In 4.5 years, they generated about 16 MWH of electricity, worth around
$1.2 megabucks. And they paid $2.8M for equipment and $1.7M for fuel.
It looks like there was a lot of maintanance costs, too.
John
You're a gas Mr. Ham... such a fool.Eeyore said:Jamie wrote:
Try using your BRAIN before talking shit (yet again) will you ?
Graham
7 cents a watt would be wonderful, but it's about 30:1 away from what
anybody is doing, even at the research level. And if we had such
power, the first rational use is to dump it into the grid, not convert
it to hydrogen at absurd net efficiency.
Low cost solar would be great, but there's no particular link to
hydrogen. Too many "advanced" energy concepts are predicated on
ultra-cheap solar power, cheap enough to waste prodigiously. That
ain't gonna happen.
John
I am already building panels for $0.07 per peak watt and installing
them in a variety of highly profitable installations. So I am
producing energy at 1/5th cent per kWh in locations that have 1900
hours of sunlight per year or more.
(7) Adding an inverter and peak power matching hardware to solar
panels cost $2 per peak watt.
So, our 1/5th cent per kWh panels - with the addition of peak power
matching, and with the addition of inverters - ends up costing 5.7
cents per kWh. Which is competitive, but even so, only 4% of the
total power can be generated this way.
Tests have been completed on the core design. I'm now putting
together production capabilities.
I'm putting together a several strings of 1,100 panels. Each string
is 4,400 ft long by 8 ft wide - wired together at the factory like
Christmas Tree lights. They are transported on a 52' flatbed trailer
z-folded together.
Jamie said:Btw.
Our Electric company is building Hydrogen generator facilities.
In sci.physics John Larkin
Rocket engines are continuous.
In internal combustion engines, the fire goes on and off.
I'm just wondering out loud what happens to the metal parts which
will be rather hot when hit with LOX.
Will thermal stress cracks be an issue?
In sci.physics JosephKK said:[email protected] [email protected] posted to
sci.electronics.design:39:36 -0700, bill wrote:
[about LOX, H2O2, etc.]
I don't know if such a thing would really work, or
what its
effects on an engine would be, but its a kinda cool idea.
I might make tinkering with it a winter project.
You'll never get back the energy it took to liquefy the O2.
Nothing is going to ignite until it is gas; that's what the
intake and compression strokes are for.
Filling a TDC cylinder with liquid fuel and liquid O2, I bet
they'd ignite real good, if the LOX doesn't freeze the fuel; you
might need a lot of energy to make a spark through it, however.
Liquids don't ignite.If you are so very sure about, that i suggest that you try mixing
unsymmetrical di-methyl hydrazine (UDMH) and red fuming nitric acid
(RFNA) (glacial). Take very serious precautions and read the
relevant MSDS before making the attempt.
Do you understand the difference between combustion and a chemical
reaction?
I thought not.
Well, I'm an engineer and I like it, especially with a
non-differentiated audience.
If the common vernacular fails, use equations.
Where? Got links?
That sounds exhorbitant. I can buy small PF-corrected switching
supplies for 25 cents a watt,
and things like this have great economy
of scale.
If you can generate electricity for 0.2 cents per kwh, you could sell
it to utilities for 25x what it costs,
so you should be a billionaire
by now. Are you?
That's true, as I haven't invented or even discovered one damn
thing. It's all old science and much older physics that hasn't
changed nor
will it likely ever change. The hard question is about
accomplishing clean energy alternatives, not about whatever's the
least spendy forms of energy on Earth that disregards human safety
as well as having otherwise pillaged, raped and trashed mother Earth
for all she's worth in the process, not to mention the likes of
collateral spendy, mostly innocent bloody and otherwise extremely
polluting wars that you folks can't seem to ever get enough of.
A sufficient mass production of those 100+ meter towers, along with
their wind turbine driven generators plus whatever extent of the
best available PVs that can also take advantage of each given tower
without devouring or otherwise contaminating precious surface ground
area seems entirely worth our doing, that is unless we surcome to
the ENRON/ ExxonMobil naysay likes of yourself and of other coal
burning and yellowcake polluting bigots for a buck, that are
anything but birth-to- grave efficient or without having traumatised
our frail environment past the point of no return.
Can you say again as to why you folks so hate humanity, and care
less about our environment?
- Brad Guth -
Anybody remember when they first started using nuclear, and
electricity was going to be virtually free?
I guess that one didn't pan out either. )-;
Rich
Prototypes plus actual installations that function have been built,
and the likes of William Mook and myself tend to stick within the
regular laws of physics and otherwise put to good use the best
available science, such as those fuel cells running so nicely on
natural gas hasn't polluted the environment or taken a bite out of
our badly overloaded grid that's getting mostly electron pumped via
coal plus h2o and extensively N2 fired, of which that nasty coal
obviously works as long as we don't mind a few thousand dead coal
miners per year, accepting global gigatonnes worth of CO2 and
otherwise butt loads of NOx and many other sorts of nasty elements
contributed down- wind or put back into surface and ground water, as
well as taken such volumes of having outright consumed and/or
vaporised precious fresh water.
Those 4+ MW producing towers have been a done deal in other parts of
this world that are not nearly as all-knowing arrogant and bigoted
as you'll find right here within this usenet cesspool of naysayers
in denial about everything that rocks their status quo good ship
LOLLIPOP, and it's mostly a Jewish ship of fools and/or rusemasters
to boot.
- Brad Guth -
Their efficiencies are far less than unity, and this is but one step
in the inversion peak power matching process and then synchronizing
with the AC grid in such a way as to contribute that power
efficiently.
You're not really getting it. Or rather, you are letting your
prejudices dictate to your mind what's possible. Which is why you are
making foolish mistakes.
To intertie to the grid would increase costs to 6 cents per kWh at
best
Based on a silly estimate of the cost of grid tied inverters which you have
overestiamted thge cost of by at least 3 times and probably more.
With a sensible supply of inverters that would be 2 cents / kWh or less.
Graham
Graham, you might be right that $2 per peak watt is high. But it is
at the high end of the envelope. Fact is, no one is building DC
intertie at the 50 MW scale and above so no one knows what all the
costs will be.
The first one won't be $0.40 per peak watt - which is
what you're suggesting I think. Though with a dedicated effort you
might get down this level. A real first system - for planning
purposes - I think $2 per peak watt is a conservative number (that is
its high - but likely the first go round)
costs will be. The first one won't be $0.40 per peak watt - which is
So, ask yourself, at what scale?
It is true economies of scale and leaerning curve effects do reduce
the cost of smaller units, and may reduce initial costs well below the
$2 estimate my detailed engineering analysis came up with.
You by comparison have merely indicated a suspicion of where intertie
might be after a decade or more of large-scale development.
The big question anyone who wants to have solar be an important source
has to ask, is where to start? After 60 years of development far less
than 1/1000th of our total energy supply comes from direct solar.
That means we're doing something wrong.
So, I decided to do something different! And I've described my
reasoning and my approach and my success. To which a blindered and
shuttered community of enthusiasts, stuck in a world where the solar
industry is dominsted by the major oil companies, cannot seem to see
the forest for the trees.
There is adequate reason to believe that when you start engineering
large DC powered interties (much larger than that found on homes) you
will pay more than the $0.70 per peak watt (10 x more than my panel
costs) first time out. More likely $2.00 per watt (3x a mature
market0.
