timer for attic fan
Z
Zoe
is there an easy way to setup a timer control for an attic mounted fan?
the only way I can think of is to install an Instamatic type (home depot sells them)
metal cased timer and wire the electric to the Instamatic which similarly like a pool
pump timer would then turn the fan on/off
the problem with this is that every time there is a power outage I would have to go on
roof to remove the attic fan covers to reset the time which is a major job
could a timer be wired to the breaker panel or another way?
JoeSpareBedroom
sells them) metal cased timer and wire the electric to the Instamatic
which similarly like a pool pump timer would then turn the fan on/off
have to go on roof to remove the attic fan covers to reset the time which
is a major job
How about putting the timer in a more accessible place? Does the fan have
its own dedicated line to the breaker box. If so...ba da bing. Problem
solved. The Intermatic timers are grey, like breaker boxes. They'll be so
happy together!
H
Harbin Osteen
is a major job
Howdy:
Most attic fans are controlled by a thermostat, is there a reason
that you would use a timer, such as you are running off a battery bank?
SeeYaa:) Harbin Osteen KG6URO
!sdohtem noitpyrcne devorppa-tnemnrevog troppus I
W
Wayne W
Most or almost all attic fans I know are controlled by a thermostat? Why
would you want an on-off switch??
"> is there an easy way to setup a timer control for an attic mounted fan?
Al Bundy
fan?
depot sells them) metal cased timer and wire the electric to the
Instamatic which similarly like a pool pump timer would then turn the
fan on/off
would have to go on roof to remove the attic fan covers to reset the
They are controlled bey thermostat as have said.
One solution, also said, was to put a switch on it. Even drop the switch
in the closet by the access if that's where the access is.
The thermostat has an adjustment on it. The MasterFlow
(http://www.gaf.com/Content/Documents/20453.pdf) goes from 60 to 120. The
recommended year round setting is 105. An option is to go up and adjust
the easily accessable screw setting twice a year. 10 second job once
you're up there. One week job to restore ceiling after stepping off truss
chord:)
Z
Zoe
Joseph said:
I am guessing the OP really has a Whole House fan not a attic vent fan.
Of course I could be wrong, but the solutions are the same in either case
the fans are literally cut out of the roof and have a sensor for both humidity and
temperature. they are embedded into a barrel tile roof.
the reason I wanted a timer was to allow them only to run on the hottest part of the
day (perhaps 3-4 hr max) as they literally make my heat pump system work harder due to
increasing humidity inside the house.
another option I like is the on/off switch which I can easily attach next to the
breaker but of course that requires me to manually remember to do this every day.
someone else suggested ripping them out and replacing them with a lower CFM rated
motors which have only a temperature control (no humidity sensor) and this would make
them run strictly based on some high temp number (ie. 110F) and at a lower speed.
George E. Cawthon
mm said:
Absolutely. The instructions that came with my roof fan suggested
this. I ran some 14-3 Romex from the thermostat, I think it was, down
one of the trusses, though the top of the hall wall. It's easy to see
walls below when you're in an attic. The top plates are visible. They
are the wood parts that go where your walls go, as opposed to the
sheetrock you see up there, which are the ceilings downstairs.
I ran it to the a nice place in the hall, near my bedroom door, and
used a single gang old-work box mounted sideways, to hold a double
toggle switch. One turns it off when the thermostat would turn it on,
and the other turns it on when it would be off. The instructions
suggested the second one to turn it on when there is a lot of humidity
in the attic. I don't take steamy showers to I never have this
(afaik), but I put it there anyhow for the next guy. It was only
anotehr 2 dollars and 10 minutes time.
The normal setting for the two switches is one off and one on, but I
could never keep track which should be on, so I put them in the normal
position and used an indelible marker to make a black line on each, so
the two lines are in line, when the switches are in the normal state.
And I turn the fan off the same times you do, late fall and early
spring, so I can use the sun to heat the attic and the attic to heat
the house. It's about another 2 weeks to a month at both ends that I
don't have to run the furnace. (although if I add more insulation to
the attic floor, I may lose this heat. Not sure these days.)
I was thinking the same thing as Joe. Does the attic fan the OP
refers to mean a whole house fan, in the floor of the attic, or a roof
fan as I call them to avoid ambiguity?
The solution is a dymo label on each direction the
switch moves. My roof fan was in when I bought it
so I just added a third line (2nd hot) that by
passed the thermostat and put a double switch box
in the ceiling of the garage(course I use a stick
to move the switches). One switch is labeled
"Power" and "off" on one side and "on" on the
other, the second reads "fan" and "on" on one side
and "auto" on the other. That gives you full control.
Tony Hwang
How about letting it run via thermal switch?
mm
How does the roof fan increase the humidity in your house. Does the
air in your attic even come in contact with the air in your house?
I didn't see this last suggestion, but it sounds terrible. If you
want to get rid of the humidity sensor**, just disconnect one wire.
The humidity sensor is iiuc set pretty high so that the fan runs only
when there is very high humidity in the attic, such as from hot steamy
baths or doing the laundry and for some bad reason venting the dryer
to the attic. Humidity in Baltimore is sometimes 60% and I don't
think sensors are set to turn on just because of that. After all, the
humidity is everywhere when it's caused by the weather, and it's just
as bad outside the house as it is in the attic. Too high humidity
does some sort of damage to the attic.
Ecnerwal
to go on
Sensible people wire the timer and/or switch in place such that it is
inside the house. The fan being in the attic does not mean the controls
for it need to be, or should be, in the attic. It's just electricity,
and wires move that to the place that is convenient.
The setup on ours is a low/off/high switch for the fan, plus a countdown
timer (up to 12 hours), so the thing is run only when the occupants feel
a need for it. If not going that route, it would probably be a good idea
to include some sort of thermostat to run your fan only when the attic
is hotter than the outside air, rather than wasting power ventilating it
when it's cooled off. In that case, a timer would not be needed.
Jim Baber
Jim Baber replies:
Trimmed.............
And if it is a whole house fan, as Joeseph suggested, then it
wouldn't be running when the heat punmp/AC is running.
You would not think so, but, I found that a short overlap (5 - 10
minutes) with a wholehouse fan and standard HVAC central system did
cause my house to cool faster than either the HVAC or the wholehouse fan
alone. I suspect quicker cool down occurred because the wholehouse fan
since it is in the ceiling pulls the hotter air (rises to the top) from
the house before it has time to mix with the cool air introduced by the
HVAC system. The air from the HVAC source tends to sink below the
wholehouse fans physical intake flow because it is cooler than the air
nearer the fan in the ceiling. There is some initial mixing and it is
increases the longer both run because of the properties of all gases.
Jim Baber
Email [email protected]
1350 W Mesa Ave.
Fresno CA, 93711
(559) 435-9068
(559) 905-2204 (Verizon IN cellphone (to other Verizon IN accounts))
See 10kW grid tied solar system at "http://www.baber.org/solarpanels.jpg"
See solar system production data at "http://www.baber.org/solar_status.htm"
I use an X10 system for this. You need an "appliance module" which you
plug in where the fan plugs in, then you plug the fan into it. You plug an
X10 controller or timer whereever you want in the house. The controller
sends a signal through the powerline to the module, which turns the fan
on or off. Google "X10" for lots of sources. Radioshack sells the same
stuff with their own name on it.
