Total voltage drop in series circuit
bitem2k
Jan 24, 2007
4
Im currently reading a book on electronics, that says that the sum of the Voltage drops across all components tied in series should equal the voltage of the battery.
However i tested cicuit on a breadboard with a led and a resistor, and measured the drops accross each and added them together. They did not add up to the supply voltage.
Anyone have any ideas?
Thanks very much. :)
audioguru2
Apr 6, 2004
12,022
Please tell us what are your voltage measurements.
Measure the battery voltage with it powering the LED when its voltage is reduced by the current.
bitem2k
Jan 24, 2007
4
Thanks for the reply.
worked out what the problem was.
This is very strange, but i was using a Nokia Charger which provides 8.78V with nothing connected., but for some reason when you measure the drops across everything connected (resistors) in series, it looses a volt or two!
Any idea why?
thanks
audioguru2
Apr 6, 2004
12,022
The voltage dropped on the Nokia charger because it is a constant current source or because it was overloaded or because it has lousy voltage regulation.
