Total voltage of 3 AC voltages
Peter
I have the following problem and I'm not sure if I did it correct:
Given v(t) =10 + 5 Sin (377t+30 degrees) - 7 Sin (377t-45 degrees)
Find VRMS
Putting them into rectangular form:
(7.07 + j 0) + (3.06 + j 1.77) - (3.5 - j 3.5)
now I add my reals and imaginaries and that's my answer? Or I can convert
that number into polar as well.
sQuick
Find VRMS
sounds like homework to me sonny..
sQuick..
Peter
sQuick..
and? I'm asking a question so I can understand it better. I've done half
the problem already!
Mike Lamond
You have also gotten the wrong results for that half. You may understand
the concept of polar to rectangular conversion, but your trigonometry math
is wrong. It helps to draw your vector, then the real and imaginary sides of
the triangle and do the math from there. Show all work. You have another
mistake but I'm not going to tell you what it is.
Back in high school trig (college prep track 1978-79), Mrs. Fliegel made
us memorize sine, cosine and tangent at 0, 30, 45, 60 and 90 degrees. We
also had to draw them freehand on trig graph paper. Calculators were not
allowed in that class!
Mike
F
Figaro
| Find VRMS
You cannot use phasor since you have a DC component.
Recall that RMS = root-mean-square.
Therefore, to obtain Vrms first calculate the square of v(t), i.e. [
v(t) ]^2.
Then integrate the result over one cycle, i.e., from t=0 to t=1/(60),
and then divide the result by 1/(60) to obtain the mean.
Take the square-root of the result.
The answer is the Vrms.
