Kevin Weddle
- Feb 23, 2004
- 1,620
- Joined
- Feb 23, 2004
- Messages
- 1,620
I underatand what you are saying, but a FET gives you the same result. A change in voltage divided by the change in current gives you the impedance. The question is , how much change in voltage will give you the change in current. With a FET, it's dependent on the gm. Maybe the gm could be any value, but I bet the gm is always high because of the biasing. This means a small change in voltage will give you a large change in current. A small gm would be ideal. Just like a reduced beta would be ideal. But a reduced beta is found with high current transistors which makes the two base resistors even lower.
