Davewalker5
- Sep 20, 2014
- 125
- Joined
- Sep 20, 2014
- Messages
- 125
What does these transistors do? U2 , 2N2920
They are placed on the op amps output pin and another transistor is placed on the input of an op amp
It seems that these transistors are used as switches to clean up or switch off so the output pin of a op amps is not leaky noise or voltage when it's off. The transistors "sinks" the op amps output to ground so the next stage doesn't amplify or create a false trigger
Take a look at the schematic
